BenQ XL2540K or Asus VG258QM
sk1p
Re: BenQ XL2540K or Asus VG258QM
Post by sk1p » 25 Mar 2021, 01:02
ezbill
Post by ezbill » 25 Mar 2021, 01:55
sk1p wrote:
25 Mar 2021, 01:02
does somebody have early access ?
sure. Don't Know if can I share it.
The monitor is 10bit with contrast of 1107 : 1 and 424 cd/m² SDR Peak Brightness.
Bad viewing angle like other TN.
Best Overdrive Setting 280Hz
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
Dark Rise / Fall Time
1.5 ms
Dark Total Response Time
4.6 ms
Dark Overshoot Error
7.8 %
Input Lag
Native Resolution
2.4 ms
Native Resolution @ 60Hz
34.7 ms
Variable Refresh Rate
2.6 ms
Variable Refresh Rate @ 60Hz
39.9 ms
10 Bit HDR
4.1 ms
Black Frame Insertion (BFI)
4.7 ms
I will receive mine tomorrow, so I can test it :D
geopsaros
Post by geopsaros » 25 Mar 2021, 05:54
Yes I do, what would u like to see?
sk1p
Post by sk1p » 25 Mar 2021, 10:07
ezbill wrote:
25 Mar 2021, 01:55
sk1p wrote:
25 Mar 2021, 01:02
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
1.5 ms
4.6 ms
7.8 %
Input Lag
Native Resolution
2.4 ms
34.7 ms
2.6 ms
39.9 ms
10 Bit HDR
4.1 ms
4.7 ms
Ty !) Input lag looks like should be higher than on mine vg279qm, it sad news.
ezbill
Post by ezbill » 25 Mar 2021, 13:22
sk1p wrote:
25 Mar 2021, 10:07
ezbill wrote:
25 Mar 2021, 01:55
sk1p wrote:
25 Mar 2021, 01:02
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
1.5 ms
4.6 ms
7.8 %
Input Lag
Native Resolution
2.4 ms
34.7 ms
2.6 ms
39.9 ms
10 Bit HDR
4.1 ms
4.7 ms
yes, seems not that great, tomorrow I will test it. Do you want to see something in particular?
ezbill
Post by ezbill » 25 Mar 2021, 13:28
speancer wrote:
25 Mar 2021, 13:22
ezbill wrote:
25 Mar 2021, 01:55
Hey man, can you post response time results for overdrive Level 4 and Level 5 please?
there is only the response time of level 3, for now is not the full review :/
speancer
Post by speancer » 25 Mar 2021, 13:40
ezbill wrote:
25 Mar 2021, 01:55
geopsaros wrote:
25 Mar 2021, 05:54
Hey, could one of you post response time results for overdrive Level 4 and Level 5 please? :)
geopsaros
Post by geopsaros » 25 Mar 2021, 14:12
Not available at the moment. The ELMB Sync seems to be much better implemented than vg259/79qm.
speancer
Post by speancer » 25 Mar 2021, 14:14
geopsaros wrote:
25 Mar 2021, 14:12
I see, thanks anyway :)
axaro1
Post by axaro1 » 25 Mar 2021, 14:15
geopsaros wrote:
25 Mar 2021, 14:12
No double pulse strobe when using ELMB-Sync?
If they actually got it right with the VG258QM it will be the first monitor they released with properly functioning ELMB-Sync (not to be confused with standard ELMB since it works correctly in every single Asus monitor).
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
