New GIGABYTE Aim Stabilizer SYNC - ASUS ELMB SYNC
Discorz
Post by Discorz » 08 Apr 2021, 04:12
New GIGABYTE monitors AORUS FI32Q and M32Q (32" 1440p IPS 170Hz) will support backlight strobing and adaptive sync working simultaneously. just like ASUS's ELMB SYNC technology. They will call it Aim Stabilizer Sync (ASS). Hopefully it doesn't perform "ass" bad :D. Specifications lists M32Q 1ms GtG, 0.8ms MPRT and FI32Q 1ms GtG, 1ms MPRT. Doesn't look good :lol:.
Quote GIGABYTE:
"Upgraded Aim Stabilizer is able to conduct the motion blur reduction and V-Sync technology at the same time! Greatly improving your FPS aim!" - https://www.gigabyte.com/Monitor/AORUS-FI32Q#tech
Its interesting how they said V-Sync and not adaptive sync.
ASUS TUF Gaming VG279QM | DELL Alienware AW2518HF | AOC C24G1 | AOC G2790PX | PHILIPS 245C7QJSB | LG W2246 | Fujitsu 17P4 CRT
Setup | Monitor UFO Motion Test Collection
SaberEdge
Re: New GIGABYTE Aim Stabilizer SYNC - ASUS ELMB SYNC
Post by SaberEdge » 09 Apr 2021, 10:55
That's good news. The more companies working on this the better. Hopefully they will be able to improve on it compared to what Asus has done so far.
axaro1
Post by axaro1 » 10 Apr 2021, 14:14
Discorz wrote:
08 Apr 2021, 04:12
This is very interesting and honestly and unexpected approach to strobing enhancement.
I can imagine some sort of algorithm/logic to prevent multiple scanout images in the same refresh.
It will be great for fps≥refresh rate scenarios.
XL2546K 1080p 240hz TN (MAIN) | VG259QM 1080p 280hz IPS | XG2402 1080p 144hz TN | LS24F350 1080p 72hz LPS
R5 3600 4.35ghz 1.237V AVX stable | 3600mhz Hynix C-Die [CJR]https://i.imgur.com/R5Rm34i.png | 5700XT Gaming OC 2059mhz 1121mv[/color]
Post by Chief Blur Buster » 05 May 2021, 14:47
axaro1 wrote:
10 Apr 2021, 14:14
It will be great for fpsrefresh rate scenarios.
There is always compromises (usually micrstutter) for framerates above refreshrate. Any claims otherwise is marketing -- but brute overkill (e.g. 300fps at 120Hz) has always been the time-honored fix, for all strobe technologies, including LightBoost from ten years ago. Strobed framerates slightly above refresh rate still has visible microstutter on all sync technologies when paying attention (e.g. tiny moving text in panning scenes).
       To support Blur Busters:
       • List of G-SYNC Monitors
       • List of FreeSync Monitors
       • List of Ultrawide Monitors
Discorz
Post by Discorz » 06 May 2021, 09:47
Seems like LG is also implementing Strobed VRR in their monitors.
Hardware Unboxed did a review on LG 27GP850 ​wich supports it - https://youtu.be/ItPCOFR5xuU?t=769
It look the same as ASUS ELMB SYNC Gen 2.
Discorz
Post by Discorz » 08 Jun 2021, 09:33
Good news for strobed vrr fans (if there are any)!
Hardware Unboxed did a review on GIGABYTE M32Q wich support Aim Stabilizer Sync.
They say It delivers similar results to classical strobing unlike ASUS ELMB-SYNC or LG's implementation. There is still some crosstalk and small amount of blur but much better than competition's.
"It does work with adaptive sync enabled and does strobe appropriate to dynamic refresh rate." https://youtu.be/tS7HYqepUZI?t=543
Red phosphor alert lol!
GIGABYTE M32Q Aim Stabilizer Sync: unfortunately they did not include ufo pursuit shots for refresh rates bellow 165Hz
GIGABYTE M32Q.png (1.56 MiB) Viewed 678 times
LG 27GP850 MBR+VRR:
ASUS PG329Q ELMB-SYNC:
ASUS PG329Q.png (2.03 MiB) Viewed 678 times
ASUS VG279QM ELMB-SYNC (not ELMB):
