NEW 2017 Motion Blur Reduction FAQ
There is now a new 2017 Display Motion Blur Reduction FAQ about monitors that has LightBoost, NVIDIA Ultra Low Motion Blur (ULMB), EIZO Turbo240, LG Motion 240, BENQ Blur Reduction / DyAc, etc. It also helps to explain what strobe crosstalk is, and the pros/cons of Blur Reduction. Check it out:
Also, if you are looking to figure out which monitor models has Blur Reduction (ULMB, LightBoost, BENQ DyAc, etc) -- including 144Hz, 165Hz, 240Hz monitrs -- check out our newly updated gaming monitor list.
2017 Official List of Gaming Monitors with Blur Reduction
- RealNC
Re: NEW 2017 Motion Blur Reduction FAQ
As far as I know, the Viewsonic XG2703 (FreeSync) does not exist and has been canceled by ViewSonic. Only the "-GS" (G-Sync) model exists.
Thank you, monitor list has been edited! This particular list is supposed to include all known monitors (on Amazon) that either (A) 100Hz+ with Blur Reduction or (B) Capable of a refresh rate above >144Hz. Unreleased (whether vaporware or newly announced) are not supposed to be included on this particular page, thanks! Generally, monitor has to be 100Hz or above to be included on this particular page.RealNC wrote:As far as I know, the Viewsonic XG2703 (FreeSync) does not exist and has been canceled by ViewSonic. Only the "-GS" (G-Sync) model exists.
There is also a relatively complete list of G-SYNC monitors here (including those without ULMB):
Official List of G-SYNC Monitors
I have an additional list of FreeSync-only monitors that are not included. A list of FreeSync monitors will be published online soon as well.
Corrections are welcome!
igluk
I really like the new design.
The blur reduction list is still missing some monitors: Samsung C27FG70, LG 38UC99 (75Hz) and LG 24GM79G
Thanks, appreciate your heads up!igluk wrote:I really like the new design.![]()
With hundreds of "Better Than 60Hz" models (Some barely so -- e.g. 1080p 60Hz FreeSync) -- it can be hard to keep track.
C27FG70 -- Added, thanks!
24GM79G -- Already have it noted offline. New model not on Amazon yet.
38UC99 -- Already have it noted offline. Excluding till tested; due to only 75Hz & reportedly excessive strobe crosstalk (unadjustable)
vadmitleo
Please tell me how to enable the LightBoost for Samsung C27FG70FQI?
For Samsung, see: http://forums.blurbusters.com/viewtopic.php?f=4&t=3544vadmitleo wrote:Please tell me how to enable the LightBoost for Samsung C27FG70FQI?
whitestar
Regarding that list of blur reduction monitors, shouldn't Benq EX2510 and EX2710 be on it (and EX2780Q)?
Also, would it be possible to list at which refresh rates blur reduction works for each monitor?
betonKruglosuTotchno
Is there a list of Pulsar monitors as well?Chief Blur Buster wrote: ↑26 Mar 2017, 16:41Thank you, monitor list has been edited! This particular list is supposed to include all known monitors (on Amazon) that either (A) 100Hz+ with Blur Reduction or (B) Capable of a refresh rate above >144Hz. Unreleased (whether vaporware or newly announced) are not supposed to be included on this particular page, thanks! Generally, monitor has to be 100Hz or above to be included on this particular page.RealNC wrote:As far as I know, the Viewsonic XG2703 (FreeSync) does not exist and has been canceled by ViewSonic. Only the "-GS" (G-Sync) model exists.
- RealNC
https://www.nvidia.com/en-us/geforce/pr ... ors/specs/
In "LCD Type" select "IPS/Pulsar". Note that the page takes a while to load.
