BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
Post by RealNC » 10 Jul 2021, 07:36
plunix wrote: ↑
10 Jul 2021, 07:27
Alright I finally got this figured out. My one hiccup is that I have a password to launch windows so I have out of range before I can get windows to launch. Do I have to blind-type the password every time now? Has there been a more permanent solution found? Thanks.
Well, you can enable auto login through the Netplwiz tool provided by Windows (press Winkey+R, enter "netplwiz" and uncheck the "require username and password" checkbox. When you apply the changes, Windows will ask for the password to use for auto login.)
That way Windows will boot directly to the desktop, logged in already.
rafraf
Post by rafraf » 14 Jul 2021, 07:00
Hello, any one Know how to overclock a xl2411p v9 firm 2019 ? Tried all method but won't go over 150hz.
Ty for reply.
aerin
Post by aerin » 24 Jul 2021, 02:41
12 Jul 2019, 18:56
Successful Universal 144Hz -> 220Hz Overclock For BenQ
For BenQ/ZOWIE 144Hz 1080P Monitors
200Hz+ Overclock Successes So Far
- XL2720 at 220Hz
- XL2720Z at 220Hz
- XL2420G at 220Hz
- XL2420T at 230Hz
- XL2536 at 200Hz
- XL2430T at 215Hz via DP
- XL2411Z at 200Hz via DVI
- XL2411Z at 210Hz via DVI using ToastyX Pixel Patcher (uncap DVI)
Record: ~260-268 Hz (and a glitched 440Hz!) on an old BenQ XL2420T, see link to photos
No S-Switch Needed!
Credit to forum member loopy750 for discovering the S-Switch 220Hz Overclock Hack for BenQ 144Hz monitors!
However, it's possible to overclock without the S-Switch! You heard about this on Blur Busters first.
And, yes, it lowers lag to less than 144Hz
Potentially Supported Models
Most 144Hz 1080p BenQ / ZOWIE monitors with DisplayPort between 2013-2019.
XL2420, XL2420T, XL2420Z, XL2420G (Classic Engine), XL2420P, XL2411P, XL2430T
Requirements
-- You need 144Hz and 1080p and DisplayPort in your BenQ/Zowie
-- Easiest with NVIDIA GPU
-- This won't work with 240Hz BenQs
-- This won't work with 1440p BenQs
-- Works with DisplayPort (~220Hz) and DVI (~200Hz). Try both ports, one may overclock higher than other.
-- IMPORTANT: For old XL2720Z (V2) do NOT combine blur reduction with overclock unless you know what you're doing (strobe backlight voltage boost bug in pre-2015 firmwares). If you dare try, set Persistence / Strobe Duty to 5 or less BEFORE you overclock.. This risk doesn't apply if you are not using motion blur reduction.
The "Out Of Range" Defeat Trick
  1. You need two monitors to make this easy initially
  2. Set your BenQ/Zowie as primary.
  3. Download [url=https:///lib/softmccs.shtm]Entech Taiwan SoftMCCS[/url]
  4. Launch SoftMCCS onto 2nd monitor (the one you're not overclocking)
  5. Launch NVIDIA Control Panel onto 2nd monitor
  6. Select the 220 Hz custom mode in NVIDIA Control Panel (create it if not already created)
    [img]https:///5zS8E2D.png[/img]
  7. Your BenQ will immediately go OUT OF RANGE
  8. Now in SoftMCCS (displayed on your 2nd monitor), click "OSD language - 0xCC" -> Activate
  9. Next, click "Display application - 0xDC" -> Activate.
  10. Doing both of the above will dismiss the OUT OF RANGE watchdog and your 220Hz will appear!
  11. For a long term fix, use an automatic utility such as /hleVqq/OorBuster (this makes SoftMCCS unnecessary) or a more recent fork such as /Chopper1337/OORbuster
To Improve 220 Hz Colors And Sharpness
  1. In SoftMCCS, select "Movie" radio button (nothing will happen until step 3)
  2. Click "Display application - 0xDC" -> Activate.
  3. 220Hz becomes visible but sharpness will go out of whack. Slide "Sharpness" to "5"
  4. The picture looks much better color quality, and graident looks fully 8bit (via GPU soft-DRC)
You will have 6-bit color depth on the DisplayPort cable but the NVIDIA GPU will be automatically doing GPU-side temporal dithering (DRC) to convert 6-bit to 8-bit. It might not always be as good quality as the monitor DRC but much better looking than 6-bit color. The GPU DRC looks nearly as good as monitor DRC if using Movie Mode.
You will have to repeat the important "OSD language" -> "0xCC" -> "Activate" in SoftMCCS steps every time you switch back into 220Hz. To prevent having to do this too many times repeatedly, make sure you have SoftMCCS running on your 2nd monitor and make sure your Desktop is 220Hz before you launch your game in 220Hz. Then Windows/Game is not doing any mode switches. Do not Alt+Enter / Alt+Tab. The single most important step is SoftMCCS window open on 2nd monitor, and ready to click "OSD language - 0xCC" -> Activate .... whenever you see an OUT OF RANGE message pop up on your monitor.
TIP:
Also, another tip is to create a mode such as 1920x1079 whose only refresh rate is the overclocked Hz. That way, games automatically have to use the overclocked Hz, and also can help reduce the number of mode switches (which can cause the OUT OF RANGE issue to come back, and need resetting again).
UTILITY:
A utility was written by hleV to reset the OUT OF RANGE every time a mode switch occurs. The utility monitors for mode switches, and automatically dismisses the OUT OF RANGE via DDC commands: ./hleVqq/OorBuster
Disclaimer: Blur Busters disclaims responsibility for any damages. Do at own risk. It works on my BenQ XL2720Z, but your mileage will vary.
Post Your Success Reports Here
I've tried this, and some more things, but I can't seem to get past 150hz without the "Out of range" error. Even OorBuster and Anti-OutOfRange did not help. I am using a Xl2411p connected to a RX 580 via a DisplayPort 1.4.
Does anyone have further advice on what I could possibly try?
Any help is appreciated.
aerin
Post by aerin » 25 Jul 2021, 09:05
Anonymous wrote: .
Exact same problem here.
Did everything you have done but with the AMD equivalent, sadly to no avail.
Have you found a fix yet?
aerin
Post by aerin » 01 Aug 2021, 16:43
aerin wrote: ↑
25 Jul 2021, 09:05
Anonymous wrote: .
Or... can anyone else maybe help with this?
jooaacoo
Post by jooaacoo » 09 Aug 2021, 05:51
Works fine on XL2430 with S-Switch at 220hz using DP. Thank u guys :d 2021
VigorouZz
Post by VigorouZz » 04 Sep 2021, 01:46
Any body having xl2411p oced to 200hz??? Am having issue
etobej
Post by etobej » 04 Sep 2021, 11:47
VigorouZz wrote: ↑
04 Sep 2021, 01:46
read the last two pages, they are all stuck at 150hz
nnnn20
Post by nnnn20 » 04 Sep 2021, 23:57
VigorouZz wrote: ↑
04 Sep 2021, 01:46
Turn off instant mode and see if it goes above 150hz. I had the same issue on my older benq, exactly at 150 as well, might be for the same reason. Alternatively what also works is using a lower horizontal (below 1400 total) total and then going directly over 200hz and skipping anything between 150-200 (yeah really). No guarantees it is the same issue but worth a try.
I managed to break my own record, 281-283hz (283hz on OSD). The screen looks very washed up but it works and plays fine :D
Post by Chief Blur Buster » 07 Sep 2021, 00:35
Neat. 281 Hz is one of the highest refresh rate overclocks I've heard of a 144 Hz monitor that has a single image full screen with only minor glitches (missing vertical pixel rows, washed out colors) -- all the higher refresh rates (400-500Hz) are heavily glitched.
