Hey guys,
I just purchased the XL2546K and I realized something happens when I signout only @240hz, The screen glitches as shown here
https://imgur.com/a/xisGvtB
I reinstalled Windows, tried the combo for Restarting GPU (Ctrl + Shift + Win + B)
Tried Reinstalling GPU Drivers and trying old ones.
Still can't get to fix it.
Can't identify if its from the GPU or The monitor.
Glitch screen on XL2546K @240hz when signing out
- axaro1
Re: Glitch screen on XL2546K @240hz when signing out
I've tested two different XL254K units and neither of those two had the issue that you described.
It looks like a defect, what cable are you using?
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
phaze
phaze
- RealNC
Check the monitor OSD to see if it switches refresh rate. If yes, then it's perfectly normal.
phaze
Nope, it doesnt change the Refresh rate.
