Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
Uchihax
Post
by Uchihax » 06 Aug 2021, 15:58
hiro wrote: β06 Aug 2021, 15:09
I also live near a big company its there since 2015, so for me its only playable in the Night. I called the power company and they will do a harmonic analysis in the next weeks but they probably think im crazy...
You can only play at night because in that company what affects you they turn it off at night, for me the big market always leaves theyr electric appliances on 24 hours a day.
This problem affects all the electronic elements in your house, for example your cell phone takes longer to charge than normal.
If you have inputlag but you do not have a company or a supermarket nearby in your neighborhood sharing the same electrical transformer, then your problem must be with a neighbor who has an electrical element that causes this problem.
Also the electrical transformers in the neighborhood that are very old must be changed, over time they break down and cause this effect. That's what that guy who works in the electric company told me.
nyxo100
Post
by nyxo100 » 06 Aug 2021, 20:16
Uchihax wrote: β06 Aug 2021, 15:58
same things here games are playable only at night
I have a neighbor who is an electrician and he said that in this sector the energy delivered by the main facilities is insufficient to maintain a stable flow of energy and that is why everything was so unstable ... in fact, where I live the electrical blackouts are constant and even several neighbors have lost electrical equipment.
In fact I can tell when everything is unstable just moving the mouse through windows feels weird and very inaccurate.
pox02
Post
by pox02 » 07 Aug 2021, 07:20
did u guys know air conditioner can cause huge amount of emi and affect the pc ? i did a test
try turn air conditioner and move right to left u will see the movement so slow turn it off movement extreme faster its was only tested without solar generator give it a try
f1ndus
Post
by f1ndus » 08 Aug 2021, 01:39
pox02 wrote: β07 Aug 2021, 07:20
you talking about what emi? like in air or its creating EMI in electricity system in house
pox02
Post
by pox02 » 08 Aug 2021, 04:26
f1ndus wrote: β08 Aug 2021, 01:39
Its in the air i even unplugged my pc and use only ups the movement still affected but my solar generator dont cause that emi so weird
f1ndus
Post
by f1ndus » 08 Aug 2021, 05:08
pox02 wrote: β08 Aug 2021, 04:26
mmm interesting, i am for sure that this problem is causing high voltage power line tower 15meters near my house, but still i dont know how can i cover and shield my pc and gear, i tried shielded every cable, maybe i try build thick metal box for pc
delve
Post
by delve » 08 Aug 2021, 05:41
pox, do you notice any difference in online games with the solar generator like hitreg, desync etc. which are not related to mouse movement?
pox02
Post
by pox02 » 08 Aug 2021, 05:53
delve wrote: β08 Aug 2021, 05:41
Good question Yes everything feels amazing hitreg no desync mouse so fast to lol its even change my dpi and sens i used to play 800 dpi and 12 sens in ow now i use 400 dpi and 7 sens huge reduction so happy
dervu
Post
by dervu » 08 Aug 2021, 06:05
pox02 wrote: β08 Aug 2021, 05:53
Could you check if there is difference between latency analyzer test results in your AW2521H monitor while being on solar generator and not?
Ryzen 7950X3D / MSI GeForce RTX 4090 Gaming X Trio / ASUS TUF GAMING X670E-PLUS / 2x16GB DDR5@6000 G.Skill Trident Z5 RGB / ASUS ROG SWIFT PG279QM / Logitech G PRO X SUPERLIGHT / SkyPAD Glass 3.0 / Wooting 60HE / DT 700 PRO X || EMI Input lag issue survivor
pox02
Post
by pox02 » 08 Aug 2021, 06:12
dervu wrote: β08 Aug 2021, 06:05
Hey i sold my aw2521h to get 390hz xv252qf
