victor910
Another step to understanding what it means is JITTER.
Jitter is a big pain for everyone.
for game developers,
for server/clients multiplayer games,
for voice engineers,
for digital audio quality., I mean real high-end devices, I2S protocol very affected by jitter, etc.
Try to read about this you will understand more deeply.
Yes, jitter is a problem, but fundamentally this does not fix your problem.
- nuggify
None of this will do anything. We tried it all.Mugabi wrote: β11 Aug 2021, 02:02I have read your three main recommendations regarding preventing electricity issues in a pc, im definitely planning to upgrade my psu which is 650w supernova gold rated (my pc is 5600x 3070gpu with 5 fans) so ill be targeting 800w platinum as well getting a high quality conditioner but my question here is, if you have a currently bad psu or bad electricity for months, would playing in such bad conditions damage your pc hardware and you would need to get brand new parts?Chief Blur Buster wrote: β10 Aug 2021, 14:44I suspect just excited/happy that his game feels less laggy -- video is probably not intended to be a benchmark video. We've been there; "I've solved a problem and I am celebrating" type of thing.
BigDog7
What do you guys think about this?
I plan on buying a small power efficient machine and running it exclusively on solar energy. It uses about same power as an average laptop: Ryzen 5 3400g and DeskMini X300 plus RAM and other small things it uses about 180w
We are buying two 200w Solar Panels so why not also do this next summer. Battery is not expensive either as the rig pulls only 180w (200w round with monitor) and I'm fine with gaming for only 1-3 hours on average.
Again I know this is not perfect solution nor it is practical for most people here but it is better than posting registry fixes
SixRavens
Literally fighting the power xDblackmagic wrote: β11 Aug 2021, 19:16
i know 1 more Russlan guy who too fight something bad and he already tried much in his apartment but it looks like he still dont solve it 100%. he even make an extra seperate power socket line into his apartment and had contact to electrics guys...
Speaking of those comments tho.. They both dont seem really knowledgeable, just trying to find anything to step on as we all do. And as we all - they are yet to succeed in their theories. My takeaway from those comments - "These are not values mere mortal can measure"(Which is not surprising since they took on interhartmonics). I might be wrong tho, but I'm yet to see any plausible fix. Their general idea is the butterfly effect, 1 wrong tick destroys stability of a whole system. Or a whole bunch of ticks, whichever you like the most) Sweet idea, but without proper testing it is of no help to us.
Btw, did you try "100% fix" from the comment under his latest 40min video? With affinities and such? Just curious
Quarksie
Can I ask which PSU are currently on the market with knowed low EMI? I have stumble upon a thread where one person advised the Corsair HS1200i as being low EMI compared to the RX1200i.
Thank you for your attention
f1ndus
stop with that, input lag and any of this problems have nothing to do with psu, dont waste your money
hiro
New psu doesnt change anything it affects all your devices console tvs . I can even see a Improvement in motion clarity with my oled tv when only Plugs into the ups batterie . I Think only solution is playing with batteries...
Mugabi
Do this if u have strong pc,but i tried to underclock my pc through bios, my cpu was 3.7ghz base,i made it 2.5ghz and i also made the ram freq from 3600mhz to 2100mhz, turned off many fans, my input lag after i restarted my pc was literally 0 i couldn't believe what i experienced, my eyes got bigger, my dick.got harder but it lasted 2 minutes then while playing something suddenly switched and it became less responsive, mind you its much better than before when i had xmp1 and ram was running full speed as well as cpu, so basically i reduced emi by reducing power ,if u play games like csgo that dont need much power/fps just reduce the shit out of it and enjoy much less input lag.
I also had hpet off,global c states off, spectrum control enabled, i noticed spectrum control helped me abit.give it a try
Mugabi
I encourage you to do a fresh windows install with updates off after u do the things i did in bios, cuz emi messed up with windows drives making them have alot error correction/lag so there might be some corrupted drivers
BigDog7
Pox, how are you connected to online when gaming on solar power? If you are using ethernet than it still means you are using power from your grid? Are you using WI-FI?
