A Blur Busters Patreon is coming later this year -- keep an eye out for it!RocketRager wrote: ↑06 Apr 2021, 17:55A real hero. If I rank up past champ, I’m donating to the site somehow lol
Does matching polling rate to monitor Hz make sense or no?
Re: Does matching polling rate to monitor Hz make sense or no?
RocketRager
100% will utilize.Chief Blur Buster wrote: ↑06 Apr 2021, 17:59A Blur Busters Patreon is coming later this year -- keep an eye out for it!RocketRager wrote: ↑06 Apr 2021, 17:55A real hero. If I rank up past champ, I’m donating to the site somehow lol
Just ordered the VG259QM. I see the owners thread with 34 pages of content....
I play exclusively rocket league. Is there a quick dirty group of settings I can just do fast and begin testing?
I’m interested in lowest response time. Maximum frames, lowest input lag, I don’t mind minimal screen tearing. I may not even notice it. I just need the maximum amount of information per second. I see all about ELMB helping with the ball tracking maybe etc.
What about my nvidia settings though? Gsync on + vsync too? No vsync? I saw somewhere someone said gsync needs vsync sometimes? Seems weird.
- axaro1
Does synchronizing SPI with USB polling events in the mouse firmware matter if you use a 240hz monitor? Does it reduce microstutters?Chief Blur Buster wrote: ↑06 Apr 2021, 17:48Theoretically Possible: Custom Frame Rate Capping Software That Syncs To Poll Rate
If you are a software developer, there is a solution
Now, there are potential workarounds, like writing a custom frame-rate capper that uses a mousehook (LowLevelMouseProc callback and the WH_MOUSE_LL event). Basically an RTSS clone that monitors the mouse poll rate and synchronizes frame rate to a divisor of the mouse poll rate. And using a 280 Hz VRR monitor to achieve the low-lag 250fps frame rate cap synchronized to poll rate (1000Hz).
Recipie:
1. VRR display
2. Refresh rate capable of syncing to poll rate
3. Custom frame rate capping software that syncs to poll rate (or divisor thereof)
However, just merely upgrading to 240Hz display refresh rate will still be a big upgrade even for refresh-rate-unsynchronized 1000Hz device poll rate.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
SPI means thousands of things to me, mostly non-mouse-related. Can you narrow down your question to something specific? Unless you’re referring to sensor rate (which is not necessarily relayed over an SPI bus).axaro1 wrote: ↑07 Apr 2021, 11:25Does synchronizing SPI with USB polling events in the mouse firmware matter if you use a 240hz monitor? Does it reduce microstutters?Chief Blur Buster wrote: ↑06 Apr 2021, 17:48Theoretically Possible: Custom Frame Rate Capping Software That Syncs To Poll Rate
Recipie:
1. VRR display
sk1p
I have Razer Viper 8kHz, 240hz IPS VG279QM, i5 8600k + gtx 1060, with 8000hz in CS GO sometimes I have insane frags, sometimes insane misses
, with 1000hz I play more stable and better, according to this theory will try to check 2000 hz )) ty
- axaro1
I mean synchronizing optical sensor data with polling events, like Razer is doing with Motionsync.Chief Blur Buster wrote: ↑09 Apr 2021, 23:13SPI means thousands of things to me, mostly non-mouse-related. Can you narrow down your question to something specific? Unless you’re referring to sensor rate (which is not necessarily relayed over an SPI bus).
It makes mousetester graph look a lot better but I'm wondering if it has some actual benefit in terms of reducing microstutters or sensor jitters.
*= currently owned
*= currently owned
DarkMartyr420
I have a XB273U GX 240hz monitor and 8khz polling mouse and keyboard. Realistically I get 120FPS in most games that I play what should I set the polling rate to?
Visual jitter experience, in the phantom array effects;Anonymous475812 wrote: ↑23 Jul 2022, 21:19How did you determine that it should be at least 6x oversample and would there be any benefit going beyond that? In example 2000Hz poll for 144Hz monitors, which is 14x oversample.Chief Blur Buster wrote: ↑06 Apr 2021, 17:09For unsynchronized poll rates, you just need to oversample by about 6x, to prevent any mouse microstutters.
It is true that 1000Hz poll is too low for 360Hz monitors, since that's only a 3x oversample, when eliminating the mouse microstutters requires a higher oversampling factor, about 4 to 6x, preferably closer to at least 6x oversample.
6x is just the minimum. Jitter can still be hugely visible, so I still recommend 2000Hz poll even for lower refresh rates.
There is more recent research (than mine), at:
viewtopic.php?f=7&t=9785
