Locked
Unixko
Post by Unixko » 08 Sep 2021, 16:33
Anarxistiwe wrote: ↑
08 Sep 2021, 13:35
Hi everyone, I'm from Russla.I will use a text translator there will be a lot.There is an apartment in the city, the wiring there is aluminum, old,there is a router in each apartment,the wires in the shield are like spiders, respectively, I have the same problem of high inputlag on the game monitor.there is a private house,the wiring is perfect,the grounding is clear, I made the circuit myself,I came to measure the resistance everything is just perfect,but here it's the same with games..I tried everything, nothing helped,even ps4 pro behaved very strangely,and there was no assist in the games at all and the picture was sickening,I lost in all online games, I couldn't even kill opponents in the back,it seemed that the game was 2 seconds behind.I bought a ups online, set it up to clearly 220 (we have 220 in Russla) and played a frequency of 60hz, it seems better, but still not that the game is lagging behind,I took a tinted hdmi on it, put ferrite filters on it again a little better,but still the game goes wrong, I read about a Network filter 3 m Brennenstuhl Premium-Protect-Line 60 000 A, 6 sockets on some medical site that it helps from interference, as a result, I bought it.I placed a ps4,a TV,a router and an Internet terminal in it,you won't believe it for 3 days the game is going well and there is a massist,the trick is certainly not the same as that of streamers,but I have one provider I can't experiment,but the fact is that I now shoot opponents 1x1 and the picture has become productive, smooth, I hope that this will remain forever, I almost forgot I didn't use ups when playing,only this network filter,I hope that it will also help you.I have returned the desire for cod warzone and other games, good luck to everyone,sorry my langvige
basic extender cord with some filtering
what ever this cord provide for you its will be for short period time
mendiguera_
Post by mendiguera_ » 08 Sep 2021, 21:35
Hi, I've been following this topic for a while and I've always felt a lot of inconsistency in my mouse. A few days ago I've been doing tests using MouseTester v1.5 and noticed a very strange graphic.
Mouses: razer viper mini and zowie fk1+ both with 1000hz
Can anyone explain to me?
Can someone with inconsistency issues test it too?
test frequency vs time
Anarxistiwe
Post by Anarxistiwe » 08 Sep 2021, 22:18
3day game ok.i hope everything will remain like this.I don't know how you can post a photo or video here.the network filter itself is https://m.youtube.com/watch?v=yQQLwVCT6W8
Sorry the video is not mine.
nick4567
Post by nick4567 » 09 Sep 2021, 02:28
02 Oct 2020, 22:44
howiec wrote: ↑
02 Oct 2020, 22:14
I'm sure someone else has said this before but as an electrical engineer, I can tell you that EMI should have zero effect on your "input lag" UNLESS you're talking about wireless networking or peripherals (e.g. mouse & keyboard).
Part 1 of 2
Actually, it's rare but it has happened. I am crossposting something else I wrote on another forum at ArsTechnica:
____________
Interference problems can create really WEIRD effects for a lot of modern gadgets. When interference is strong enough -- and/or the shielding is weak enough.
Like the LG 5K display that glitched if a WiFi router was nearby.
I've also gotten anecdotes from spectrum-analyzer using engineers/techs where they found weird videogaming sutters/glitches caused by electricity noise.
The interference was nearly (but not quite) strong enough to crash a computer. Instead, the computer was severely slowing/lagging from apparent error correcting behaviours.
We don't know what specific slowdowns were caused by -- flood of IRQ interrupt noise or error-correcting behaviours on SATA cables or noise on ECC DRAM buses or some other mysterious EMI-based slowdown effects, or a PCI Express bus trying to retransmit data during noise errors -- probably error correcting by the millions, like death by a million nanoseconds or microseconds that added up to continually visible slowdowns (game stutter, Window-dragging stutter, scrolling stutter, etc). Even when nothing was running in background (CPU/GPU near 0%), and scanners found no viruses.
Like thousands of microfreezes per minute.
The computer really performed erratically slow in a way that wasn't blameable on Microsoft Windows in particular as patterns persisted regardless of what was installed or reinstalled. And it was only when the interference was occuring. When the culprit appliance was removed, the computer went back to full speed. The engineer's testing equipment confirmed massive interference noise was somehow being injected into the computer that slowed down / stuttered everytime the noise occured. The massive amounts of error correction layers that portions of a modern computer has, apparently prevents the computer from crashing.
It's possible some components were suboptimal/defective or it was a cheap motherboard, or a poorly EMI-rejecting computer power supply. But at some point, some forms of interference can become too strong for a hardened computer to resist fully. And they apparently don't always crash right away thanks to all those error-correcting buses (PCI, SATA, NVMe, ECC RAM, USB, LAN, DisplayPort, etc, all of which use error correction now). It can be bad enough like an Internet connection losing 50% of its packets, but on a PCI Express bus, or USB cable, or NVMe SSD or whatever -- things really slow down there too if interference is strong enough but still lets enough data through that the computer doesn't crash.
All the numerous error correcting buses found in modern PCs, that didn't exist 25+ years ago. Error correction behaviours often involve latency, including bandwidth reductions or retransmission latency or extra wait states or ultrabrief computer freezes, etc. We don't know which error correcting layer occured, but we know computer reliably sped up/slowed down everytime the known electrical interference was added/removed.
Usually error corrections in a PC on these layers are nanoseconds or microseconds but they can apparently daisychain by the thousands into visible milti-millisecond microfreezes covering multiple display refresh cycles! Which just appears as stutter (choppy motion on a screen). It's hard to diagnose exact causes of specific stutters (from driver bugs or thermal throttling or background processing).
But apparently, this computer slowdown was EMI-caused -- visible stutter from electricity noise coming from the power outlet!
There's a ton of weakly-shielded cheap electronics or even shielding-defective high end electronics. And time can degrade many device like these TVs degrading into unintentional small-scale EMPs.
Very weird!
_____
--end of crosspost; begin of reply--
WARNING / CAVEAT: This is usually a wild goose to a red herring more than 99% of the time. However, it's not out of the realm of possibility for strong-enough EMI to start "thousand-microfreezes" lagging an insufficiently-shielded PC. The type of "EMI strength + shielding weakness" combo that is strong enough to almost, but not quite, crash a PC. I've seen at least a few examples in the last few years. TL;DR: EMI can cause computer lag as described, BUT it's very rare. It definitely ain't a five-sigma "No", just rare. Unless you have the time and absolutey exhausted other avenues, do not waste time troubleshooting longshots; troubleshoot the low-lying apples first!
Anyone here know a software or where to check to see retransmits or reported error rate in the pci/sata busses
SixRavens
Post by SixRavens » 09 Sep 2021, 06:31
Is there anyone knowledgeable enough to tell if there is a significant difference between this Brennenstuhl and APC Essential SurgeArrest PM6U?
skkiNN
Post by skkiNN » 09 Sep 2021, 06:50
SixRavens wrote: ↑
09 Sep 2021, 06:31
I need this information aswell for understanding if is worth give a try!! Lets us know guys (i have apc pm5)
Thatweirdinputlag
Post by Thatweirdinputlag » 09 Sep 2021, 16:17
the answer to your question lies within their filtration I believe, at which frequency does the filter starts doing its job and how hard does it flatten the line.. I watched a video on a guy testing one of the EMI filters with an oscilloscope, and the higher the frequency he added to the power line the stronger it got flattened.
hiro
Post by hiro » 10 Sep 2021, 15:41
Got reply from my power company and my Problem is Harmonic Distortion as expected, which they will fix with active harmonic filters because its over the limit or something and it can damage devices when not fixed. Got a new fusebox, grounding and connections to the house aswell. I will report back if it changes anything, they said it takes like 2-3 weeks....
nick4567
Post by nick4567 » 10 Sep 2021, 16:29
hiro wrote: ↑
10 Sep 2021, 15:41
Fucking beautiful mate i called my poco few days ago to come out and test for a power quality analysis AND interference (you have to ask for that separately) anyways theyre coming out on monday best of luck to you mate
Mugabi
Post by Mugabi » 10 Sep 2021, 16:31
hiro wrote: ↑
10 Sep 2021, 15:41
Wtf is harmonic distortion and whats the main source of it?
Locked
