Reduce Input Delay (Mouse & Keyboard Buffer Size)
Eonds
Re: Reduce Input Delay (Mouse & Keyboard Buffer Size)
Post by Eonds » 14 Sep 2021, 20:40
Rallaz wrote:
14 Sep 2021, 10:44
@Eonds
here are the screenshot you asked for
Yeah those look correct. There's a noticeable using it though. I guess you're just not seeing it as well or you have some other hardware issues masking it. It's much easier to see changes in latency when you're on properly tuned high end equipment.
Rallaz
Post by Rallaz » 14 Sep 2021, 21:01
Eonds wrote:
14 Sep 2021, 20:40
Rallaz wrote:
14 Sep 2021, 10:44
@Eonds
Yeah I know =P
Mine just gets better at night, ethernet or not doesnt matter
slaver01
Post by slaver01 » 15 Sep 2021, 03:45
Rallaz wrote:
14 Sep 2021, 10:44
@Eonds
Why do you have buffer value 0 on mouse and keyboard?
Rallaz
Post by Rallaz » 15 Sep 2021, 04:02
slaver01 wrote:
15 Sep 2021, 03:45
Rallaz wrote:
14 Sep 2021, 10:44
@Eonds
Because I could not measure any improvements, so @Eonds asked me to try this.
slaver01
Post by slaver01 » 15 Sep 2021, 04:34
Rallaz wrote:
15 Sep 2021, 04:02
slaver01 wrote:
15 Sep 2021, 03:45
Rallaz wrote:
14 Sep 2021, 10:44
@Eonds
The result?
Rallaz
Post by Rallaz » 15 Sep 2021, 09:48
slaver01 wrote:
15 Sep 2021, 04:34
Rallaz wrote:
15 Sep 2021, 04:02
slaver01 wrote:
15 Sep 2021, 03:45
Rallaz wrote:
14 Sep 2021, 10:44
@Eonds
The result?
Was the same as before.
I want to remember that I have also modified my kb and mouse plus usb ports to run at 1000hz can that be why I dont feel these tweaks?
Would 1000hz be better then this tweak or wise-versa
slaver01
Post by slaver01 » 16 Sep 2021, 09:09
Rallaz wrote:
15 Sep 2021, 09:48
slaver01 wrote:
15 Sep 2021, 04:34
Rallaz wrote:
15 Sep 2021, 04:02
slaver01 wrote:
15 Sep 2021, 03:45
The result?
1000hz it's standard
Eonds
Post by Eonds » 16 Sep 2021, 21:44
Rallaz wrote:
15 Sep 2021, 09:48
slaver01 wrote:
15 Sep 2021, 04:34
Rallaz wrote:
15 Sep 2021, 04:02
slaver01 wrote:
15 Sep 2021, 03:45
The result?
I'm not sure exactly how that program works. Get a cosair k65 mini (8khz polling rate + 4khz scan rate, & Razer 8khz and you'll be fine.
Rallaz
Post by Rallaz » 16 Sep 2021, 22:53
Eonds wrote:
16 Sep 2021, 21:44
Rallaz wrote:
15 Sep 2021, 09:48
slaver01 wrote:
15 Sep 2021, 04:34
Rallaz wrote:
15 Sep 2021, 04:02
The result?
Tried that 4 months ago? It was actually extremely worse
Eonds
Post by Eonds » 17 Sep 2021, 02:21
Rallaz wrote:
16 Sep 2021, 22:53
Eonds wrote:
16 Sep 2021, 21:44
Rallaz wrote:
15 Sep 2021, 09:48
slaver01 wrote:
15 Sep 2021, 04:34
The result?
Tried what? A better mouse and keyboard doesn't make your pc worse, yes the polling rate is more "taxing" on cpu resources but if you have a properly optimized os then it's not an issue.
