High input lag and desync
naporitan
Re: High input lag and desync i5 9600kf
Post by naporitan » 07 Oct 2021, 21:51
bad hitreg
dervu
Re: High input lag and desync (Problem solved.)
Post by dervu » 08 Oct 2021, 05:33
naporitan wrote: ↑
07 Oct 2021, 21:51
By contacting the energy company, the problem is solved.
So what did you tell them and how did they answer?
naporitan
Post by naporitan » 08 Oct 2021, 05:36
I just wrote that the quality of electricity is bad, made my own independent measurements and asked to take action, and the indicator of the quality of electricity is the level of harmonic distortion across the spectrum of frequencies.
naporitan
Post by naporitan » 12 Oct 2021, 02:30
The problem is back after 5 days, waiting for the harmonic filter.
1008SKS-SHF-0010-2C5-15 (1).pdf
(1.03 MiB) Downloaded 250 times
wadge
Post by wadge » 12 Oct 2021, 13:49
naporitan wrote: ↑
12 Oct 2021, 02:30
Can you explain how you proceed to install this filter ? or make a DIY ?
Where did you ordered yours ?
naporitan
Post by naporitan » 12 Oct 2021, 23:46
http://sikes-elec.com/filter/single-pha ... ic-filters
It is unlikely that you will be able to make your own hands such a filter.
naporitan
Post by naporitan » 13 Oct 2021, 02:56
I want to warn some people are misleading and do not want others to solve the problem...
Thatweirdinputlag
Post by Thatweirdinputlag » 13 Oct 2021, 06:31
What did the power company do in the first place?
naporitan
Post by naporitan » 13 Oct 2021, 06:45
Thatweirdinputlag wrote: ↑
13 Oct 2021, 06:31
n0thing... I've just been duped... All hope for the harmonic filter.
wadge
Post by wadge » 13 Oct 2021, 12:43
Ok but how do you install it ?
