Acer 390Hz monitor - XV252QF
lyrill
Post by lyrill » 25 Oct 2021, 18:04
lizardpeter wrote:
25 Oct 2021, 14:53
woland wrote:
25 Oct 2021, 14:35
The viper8k may be better than other mice in theory, but not necessarily in practice. In a real setting the lack of a wire resulting in easier and more consistent movement and lower weight of the gpwx typically result in the gpwx outperforming it. Evidence to this is the complete lack of pro players using the viper8k and the near dominance of the gpw and other viper models. My own personal experience in Kovaaks and Apex matches it. The wire is more of a hinderance than the polling rate improvement, I simply perform better with the gpwx.
Simply put, I don’t see any need for wireless peripherals when I’m sitting stationary at my desk.
You also have to be careful with “pro” players. they just grind a lot
spout that truth m8. would upvote if there is such a forum feature here.
woland
Post by woland » 26 Oct 2021, 19:51
lyrill wrote:
25 Oct 2021, 18:02
woland wrote:
25 Oct 2021, 14:35
only if u are low edpi. which is again, objectively and subjectively(duh) inferior.
I'm not on low edpi. Your theory crafting is grand, but takes little account for reality and nuances of aiming, in which you seem rather poorly versed.
Notty_PT
Post by Notty_PT » 27 Oct 2021, 08:19
Razer Viper 8k hz is objectively and technically the best mouse available right now. However the shape is a very important factor when using a mouse. If you cant aim well with that shape, 8k hz Will not help you, even if you notice it smoother.
As for wireless mice, I stay away. I don't care what others say. Using wireless mice on 200hz+ refresh rate makes me notice the polling rate inconsistências
And I hate that reviewers still compare wireless vs wired using click latency... I can literally show a 125hz polling rate mouse having lower click latency than a 1000hz one. We should be testing sensor response, behaviour and consistency at different movement speeds, not click latencies
lyrill
Post by lyrill » 27 Oct 2021, 10:38
woland wrote:
26 Oct 2021, 19:51
lyrill wrote:
25 Oct 2021, 18:02
woland wrote:
25 Oct 2021, 14:35
nuance of aiming is achieved by highest possible edpi and lowest possible cm 360 and littlest body stance jitter, there's nothing grand about basic science.
lyrill
Post by lyrill » 27 Oct 2021, 10:41
Notty_PT wrote:
27 Oct 2021, 08:19
gwtest has been for 2 years. but they are still fixated on paid reviews of keyboard tests cheaper chinese brands etc which is a shame. recently they are using 10 basic level cloth pads to test a couple mice, none of them of any real interest
IIISLIDEIII
Post by IIISLIDEIII » 27 Oct 2021, 11:51
can someone who has this monitor and who plays cod warzone tell me how it behaves at fps around 180-200?
Is it still worth it?
lyrill
Post by lyrill » 28 Oct 2021, 05:00
IIISLIDEIII wrote:
27 Oct 2021, 11:51
i play bfv at 200+ fps dipping below as well. it behaves nicely.
3 weeks afk after basically playing the odd game twice a month previously for like a year anyways. og beta tester and only like 6-700 hrs total, most of it from 2018-9. feeders but my team is noob as always so. no hacker custom server (i think). joined halfway as well. casual top kill. the super sharpness is def a +
IIISLIDEIII
Post by IIISLIDEIII » 28 Oct 2021, 05:47
lyrill wrote:
28 Oct 2021, 05:00
IIISLIDEIII wrote:
27 Oct 2021, 11:51
I'm trying to figure out if do 200 fps on screen at 390hz is better than doing 200fps on 240hz?
IIISLIDEIII
Post by IIISLIDEIII » 28 Oct 2021, 09:55
if the panel does 390 updates per second it certainly has a more reactive and faster response in game than a panel that does "only" 240 updates, but this is assuming to be able to do 390fps.
If I do 200 fps on a 390hz what do I perceive different in my gameplay compared to doing them on a 240hz?
there are more or less tearing?
Another doubt I have is on the backlight strobing, if I do 200fps does it still work fine or does it only work fine if I am going to 390fps?
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 28 Oct 2021, 10:16
