Good 1440p monitor with minimal ghosting/ invert ghosting/ blur?
maou42
Post by maou42 » 29 Sep 2021, 18:38
Hi
I would like to purchase a new monitor for gaming.
Could someone recommend one with very little bluring/ ghosting/ overshoot?
I am not too fussed about the max refresh rate but I would love some G-Sync compatible panel.
Thank you
sk1p
Re: Good 1440p monitor with minimal ghosting/ invert ghosting/ blur?
Post by sk1p » 30 Sep 2021, 00:45
Hi, Acer xb273ugx/ASUS XG27AQM/Asus PG279QM
I have Acer xv272ux(Freesync model) and really love this panel, TN clarity and no input lag, don't see there ghosting/blur or inverse ghosting, quality with the same panel should be little bit better with ASUS XG27AQM, but Acer has lower price.
maou42
Post by maou42 » 30 Sep 2021, 11:13
Thank you for the replies.
I had seen the list of suggested monitors but it does not lead to reviews and is therefore if limited use.
Handler
Post by Handler » 30 Oct 2021, 14:50
Asus PG279QM
LG 27GP850
Alienware AW2721D
Check Hardware Unboxed reviews on youtube, they test for this.
maou42
Post by maou42 » 31 Oct 2021, 21:55
Handler wrote:
30 Oct 2021, 14:50
Asus PG279QM
LG 27GP850
Alienware AW2721D
Thanks. I got the LG 27GL850
Boomchakadah
Post by Boomchakadah » 31 Oct 2021, 23:01
Acer XV272U Kvbmiiprzx
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
maou42
Post by maou42 » 02 Nov 2021, 00:10
Boomchakadah wrote:
31 Oct 2021, 23:01
Thanks but as I said, I have already bought the LG 27GL850 b
Very happy with it. Amazing monitor.
Boomchakadah
Post by Boomchakadah » 02 Nov 2021, 03:15
maou42 wrote:
02 Nov 2021, 00:10
Boomchakadah wrote:
31 Oct 2021, 23:01
That 170Hz Acer XV272U Kvbmiiprzx has less ghosting and better out of the box colors than your LG 27GL850 https://www.rtings.com/monitor/tools/co ... shold=0.10
Since you said that you're not too fussed about the refresh rate, I thought 170Hz would be enough. if you want a 240Hz 1440p, get the ASUS XG27AQM.
