So have you tried to use the same timings in CRU?
Overclocking MSI Optix MPG341CQR to 215 Hz [SUCCESS]
- RealNC
Re: Overclocking MSI Optix MPG341CQR to 215 Hz [SUCCESS]
LOV
LOV
Ok, i found the solution and it works perfectly
I've deleted custom resolutions from NVIDIA Panel
Launch CRU delete everything then,
Add 1 Extension Blocks > DP 1.3 > Detailed resolutions > Add > I copied the exact same timings from NVIDIA Panel > Launch restart64.exe
If you have this monitor, I advise you to use 214hz because ALT+TAB is bugged with 215hz (Black Screen, DP not detected)
PROBLEM SOLVED
PROBLEM SOLVED
