Except where the heck do you buy this monitor?! I’ve looked everywhere and can’t seem to find to the X25 or the Acer 390hz available to buy…IIISLIDEIII wrote: ↑30 Nov 2021, 18:29I recommend you to try Omen x25, you will not regret the dyac, believe me
Comparison benq xl2546k, hp omen x25, acer nitro xv252qf,msi mag251rx
Re: Comparison benq xl2546k, hp omen x25, acer nitro xv252qf,msi mag251rx
Here in europe Amazon still has them. If im not mistaken u can order from the USA from EU and vice versa. Check out the amazon.fr amazon.nl amazon.de amazon.co.uk sites. u just need to use a different power cable if im not wrong also.StarWarsCoffee wrote: ↑14 Dec 2021, 22:50Except where the heck do you buy this monitor?! I’ve looked everywhere and can’t seem to find to the X25 or the Acer 390hz available to buy…IIISLIDEIII wrote: ↑30 Nov 2021, 18:29I recommend you to try Omen x25, you will not regret the dyac, believe me
| Now:
| Past: XL2586X 540Hz/PG248QP/271QRX/VG259QM with the Qisda panel/PG27AQN/XL2566K
I looked and they're all second hand retailers asking way too much money it seems :\daviddave1 wrote: ↑15 Dec 2021, 15:37Here in europe Amazon still has them. If im not mistaken u can order from the USA from EU and vice versa. Check out the amazon.fr amazon.nl amazon.de amazon.co.uk sites. u just need to use a different power cable if im not wrong also.StarWarsCoffee wrote: ↑14 Dec 2021, 22:50Except where the heck do you buy this monitor?! I’ve looked everywhere and can’t seem to find to the X25 or the Acer 390hz available to buy…IIISLIDEIII wrote: ↑30 Nov 2021, 18:29I recommend you to try Omen x25, you will not regret the dyac, believe me
they are still "new". Its a returned product to amazon. The store has to be amazon warehouse though. double check thatStarWarsCoffee wrote: ↑15 Dec 2021, 20:21I looked and they're all second hand retailers asking way too much money it seems :\daviddave1 wrote: ↑15 Dec 2021, 15:37Here in europe Amazon still has them. If im not mistaken u can order from the USA from EU and vice versa. Check out the amazon.fr amazon.nl amazon.de amazon.co.uk sites. u just need to use a different power cable if im not wrong also.StarWarsCoffee wrote: ↑14 Dec 2021, 22:50Except where the heck do you buy this monitor?! I’ve looked everywhere and can’t seem to find to the X25 or the Acer 390hz available to buy…IIISLIDEIII wrote: ↑30 Nov 2021, 18:29I recommend you to try Omen x25, you will not regret the dyac, believe me
| Now:
amazon.it, available new at 299 € right nowStarWarsCoffee wrote: ↑14 Dec 2021, 22:50Except where the heck do you buy this monitor?! I’ve looked everywhere and can’t seem to find to the X25 or the Acer 390hz available to buy…IIISLIDEIII wrote: ↑30 Nov 2021, 18:29I recommend you to try Omen x25, you will not regret the dyac, believe me
also available acer at 618€ right now
Hello, I still have the dell alienware aw2518hf, I mean it is from 2017. Would it be an upgrade to the Omen x25?
Good question. Can someone provide an answer? The version "f" was tested on the rtings site, as I understand it. All indicators of the "f" version. From here it is not clear to me why some people say that the version without "f" is better, because the same people will not use g sync in competitive games.
monitors: TN ACER 1916 (75Hz)>TN ACER 1917 (75Hz)>XL2540K (240Hz)>IIYAMA MASTER VISION PRO 451 (CRT 160 Hz)>xl2546k>omen x 25>24g2zu>xv252qf
the only difference is free and gsyn. why should HP prefer nvidea and make it better.
I am not 100% sure but I think the g-sync panel has variable overdrive. I tried the x 25f, response times were very good at 240hz with lvl 3 overdrive though.antiblur wrote: ↑23 Dec 2021, 13:50Good question. Can someone provide an answer? The version "f" was tested on the rtings site, as I understand it. All indicators of the "f" version. From here it is not clear to me why some people say that the version without "f" is better, because the same people will not use g sync in competitive games.
What do you think about the IPS panels vs the TN panels in terms of visibility and clarity in FPS games for spotting enemies? Do the IPS panels provide any advantages in this regard?
