High kernel timer latency value
Anonymous768119
Post by Anonymous768119 » 09 Jan 2022, 18:15
Just checked my kernel latency and it indicated ridiculously high values. Is anybody here who faced it before and maganed to fix it?
Additionally
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: steam.exe
Total number of hard pagefaults 42059
Hard pagefault count of hardest hit process: 7029
Number of processes hit: 96
I mentioned already, that there is some relation between sound and gameplay experience in CS:GO. Any ideas what is causing it?
InputLagger
Re: High kernel timer latency value
Post by InputLagger » 09 Jan 2022, 19:04
a_c_r_e_a_l wrote:
09 Jan 2022, 18:15
Definitely it is. Did you already try spray from AK with volume "0" and "1" in the console?
Anonymous768119
Post by Anonymous768119 » 09 Jan 2022, 19:08
I did, there is noticable difference.
heavywe
Post by heavywe » 09 Jan 2022, 21:04
a_c_r_e_a_l wrote:
09 Jan 2022, 18:15
I remember there was a time where the sound that was produced when I dominated someone in deathmatch mode, that sound took away 100% of the input lag, it was grotesque to be able to kill everyone with 1 bullet for a few seconds :(
WelcomeInNewWorld
Post by WelcomeInNewWorld » 10 Jan 2022, 09:08
if you are talking about CS:GO, for the sound it is better to configure the sound in Windows, so maybe you need to update the firmware of your headset
Thatweirdinputlag
Post by Thatweirdinputlag » 10 Jan 2022, 18:52
I've already explained to another member here how to work around this, you can check out my posts on his topic..
viewtopic.php?f=10&t=9517
chenifa
Post by chenifa » 17 Jan 2022, 07:20
@a_c_r_e_a_l
Try this:
1) Reboot PC
2) Open latencymon and press start
3) Open chrome and play a youtube video
4) Don't minimze chrome or switch tabs
5) Bring latencymon to the foreground and see if the latency changed
