Replace QPC to RDTSC Timer in games
pox02
Re: Replace QPC to RDTSC Timer in games
Post by pox02 » 09 Jan 2022, 09:47
my final fix for rdtsc
To prevent this the programmer must serialize the the instruction queue. This can be done by inserting a serializing instruction like CPUID instruction before the RDTSC instruction
Code: Select all
.code
  GetCycleCount proc
    cpuid
    rdtsc
    ret
  GetCycleCount endp
end
Ilim
Post by Ilim » 10 Jan 2022, 12:01
how to use it, tell me, otherwise I don't understand programming
pox02
Post by pox02 » 11 Jan 2022, 10:04
i would like to avoid SetProcessAffinityMask/ SetThreadAffinityMask and change freq more for much more stable rdtsc i suggest use processhacker taskmgr process lasso and disable core 0 there much better
Code: Select all
LONGLONG GetFrequency(DWORD sleepTime)
    LARGE_INTEGER fq, st, ed;
    QueryPerformanceFrequency(&fq);
    QueryPerformanceCounter(&st);
    LONGLONG begin = GetCycleCount();
    Sleep(sleepTime);
    QueryPerformanceCounter(&ed);
    LONGLONG usec = (ed.QuadPart % st.QuadPart) * 1000000 / fq.QuadPart;
    LONGLONG end = GetCycleCount();
    return (end - usec - begin) * fq.QuadPart / (ed.QuadPart - st.QuadPart);
pox02
Post by pox02 » 13 Jan 2022, 16:52
My Final update of RDTSC is using RDTSCP which more efficiently now we back to use SetThreadAffinityMask in core 0 since without its can cause drift time and loops in cores reduce the freq to 1 microsecond more efficiently Enjoy the best timer :D
RDTSC + CPUID (in reverse order, here) to flush the pipeline, and incurred up to a 60x overhead (!) on a Virtual Machine (my working environment) due to hypercalls and whatnot. This is both with and without HW Virtualization enabled.
Most recently I've come across the RDTSCP* instruction, which seems to do what RDTSC+CPUID did, but more efficiently as it's a newer instruction - only a 1.5x-2x overhead, relatively.
i update here so u guys can compile it https://github.com/Zcytxcbyz/DLLHighResolutionTimer
Plznoinputlag
Post by Plznoinputlag » 13 Jan 2022, 17:06
pox02 wrote:
13 Jan 2022, 16:52
but u cant use this in online games useles thing
uzbek
Post by uzbek » 27 Aug 2022, 19:28
pox02 wrote:
26 Dec 2021, 11:47
i would like to update code so u guys get more game feeling by using the function QueryThreadCycleTime enjoy :D
Code: Select all
    QueryThreadCycleTime(GetCurrentThread(), &st);
    Sleep(sleepTime);
    QueryThreadCycleTime(GetCurrentThread(), &ed);
    return (end - begin) * fq.QuadPart / (ed.QuadPart - st.QuadPart);
hi how i can use it?
Cyanide_
Post by Cyanide_ » 28 Aug 2022, 23:30
Plznoinputlag wrote:
13 Jan 2022, 17:06
And he posted it on Overclock electricity issue forum, like some DLL would help vs electricity caused "input lag/delay" lmao
