BenQ XL2411Z upgrading
wired2k7
Post by wired2k7 » 29 Jun 2014, 14:34
After upgrading to the v2 firmware version, if I use the Vertical Total 1350 Trick, I can't enable Blur Reduction, because all I get is a black screen until I turn off Blur Reduction or I set the native resolution to any other besides the Vertical Total 1350 Trick one, any thoughts or help about this problem? , thanks in advance
masterotaku
Re: BenQ XL2411Z upgrading
Post by masterotaku » 30 Jun 2014, 09:29
You have to use the blurbusters utility and set the crosstalk setting to the top left. You can do the same in the service menu.
Monitor: Asus PG278QR
wired2k7
Post by wired2k7 » 30 Jun 2014, 09:41
I did that and it fixed the problem, the problem was my strobe crosstalk didn't go to 00 it was on 100, as soon as I set it to 00 problem solved, thanks for trying to help MasterOtaku appreciated, have a good day.
