Can anyone tell me what it is? (SOLVED?)
- Slender
It all started with the fact that once I sat down at the computer and how many on this forum started complaining to me about the mouse. But the fact is that I spent a lot of time to understand how everything works and make my mouse perfect, at least I thought so. But one day everything changed. I do not know what this is related to, but I started getting a strange delta on my chart, at about 990-1010. Yes, many will say that this is good, but the fact is that something has broken. I tried everything - reinstalled windows, flashed BIOS, GOP, changed the motherboard, RAM, video card, and today I changed the power supply. The only thing I haven't changed is the processor.
Strange intervals, I thought it was a problem in the power supply, but it's not. Today I noticed that when I move the mouse I get a squeak from the power supply (more in the video). I really don't understand the reason. The only thing you can sin against is the processor. What do you think? https://youtu.be/LDEOJtn1Cd8
My config:
asus tuf z390 plus
9700kf
3060ti / 1080 ti / 650
gskill 3200 cl14
masterwatt 600
revi os 21h2 / windows 21h2
My config:
asus tuf z390 plus
9700kf
gskill 3200 cl14
masterwatt 600
- 2.PNG (26.65 KiB) Viewed 14241 times
- 1.PNG (126.56 KiB) Viewed 14241 times
- Slender
Re: Can anyone tell me what it is?
"before"
- 3.PNG (43.76 KiB) Viewed 14239 times
- win10.png (160.42 KiB) Viewed 14239 times
InputLagger
Dude, youre have near excellent graphs with very small variations...
You can check mine, for compare viewtopic.php?f=10&t=9304&p=73941#p73941
I'm still don't find the solution
- Slender
i see this, what config?InputLagger wrote: ↑25 Jan 2022, 20:10Dude, youre have near excellent graphs with very small variations...
WelcomeInNewWorld
You have a problem for sure. On your graphic actually something is wrong, withtout any problem you should have a graphic like you had before. Im in same situation i can't help you bro i don't what's the problem
- Slender
Anyway, thanks for the support, I thought I was crazy.WelcomeInNewWorld wrote: ↑27 Jan 2022, 06:57You have a problem for sure. On your graphic actually something is wrong, withtout any problem you should have a graphic like you had before. Im in same situation i can't help you bro i don't what's the problem
WelcomeInNewWorld
you welcome
Did you use the last version of Mousetester ? it's important. Here the last version : https://github.com/microe1/MouseTester/ ... ester_v1.4
also you need to close every programms backside, all programm
- Slender
I am testing my computer with 0 third-party processes in the background, I also use version 1.5.3 which shows the frequency, and before the problem I used the same version, so I believe that the problem is not in it. I've already tried everything I could and I don't think there will be a genius who will offer me a fix, because I'm already starting to think that it simply doesn't exist.WelcomeInNewWorld wrote: ↑27 Jan 2022, 11:10you welcome
paddyhhh
@slender
could you please explain exaxctly what you did to get such a graph?
Thanks
Thanks
- Slender
