Electricity input lag fix !
WelcomeInNewWorld
Re: Electricity input lag fix !
I don't understand why the author of this topic was not more precise in his explanation with screenshots with more precise information because it is a bit vague ...
Lautreamont
Hi. Thank you so very much!! <3
Same problem for 2 years. There is no hardware left that I haven't changed in 2 years. I also renewed equipment such as mouse, keyboard, headphones. But my problem has always been. I used to set "c states" to always off before. I just did Enable for the first time and my problem was fixed. By the way, I also found a 40% fix for the inputlag problem. This is more weird. It gets better when I set the mouse's DPI to 3000+. Or, when I set fps_max 144 in the example CS:GO game from within the game, the input lag was gone. I have a 240hz monitor. I was following this forum. Sorry for my bad english. But thank you so much man!
GodOFCl1toris
Can someone help me do this? i Have z370 A Prime motherboard, faceit 4k elo please help
Plznoinputlag
why u need this? if u can reach 4k elo faceit you dont have this problems u all good.GodOFCl1toris wrote: β06 Feb 2022, 14:35Can someone help me do this? i Have z370 A Prime motherboard, faceit 4k elo please help
Was messing with ram kits recently. The worse kits with higher total latency do better in my environment when "EMI" is present. Pretty funny.
3200 cl14, 3600 cl16 both feel worse than an average 3200 cl16 bin. Just defaulting to JEDEC should have a similar impact.
I also came to the conclusion that there must be something to do with the ram like every time i start the game after the pc has been shut down for a day the first game is perfect in term of hit reg and stuff no delay but after that even if you reboot it reminds the same, desync and all that.
I noticed it at every place i used to leave, even overseas.
I tried the software to empty the standby list memory but it doesn't help...
The thing is, at least for me, my cable coax/ground is influencing my "EMI". If I remove cable/turn off modem, the better kits definitely feel more responsive.wadge wrote: β09 Feb 2022, 09:16I also came to the conclusion that there must be something to do with the ram like every time i start the game after the pc has been shut down for a day the first game is perfect in term of hit reg and stuff no delay but after that even if you reboot it reminds the same, desync and all that.
Like I said in an earlier post, the issue as I perceive it is that the Input lag is lower when "EMI" is influencing my PC. Higher latency offsets it. Be it lower monitor hz, lower polling rate.. etc.
I just find it interesting that a basic 3200 CL16 low tier bin helps me offset this issue. I've always purchased top end/low CL latency kits.
Kinda curious bout DDR5 now. High frequency but the timings put total latency above 10ns in most situations on current XMP profiles.
Plznoinputlag
i feel the same issue when i unplug the modem from the outlet its more responsive and tried to ply with 4g mobile internet the bad hitreg and prefires still there. i tried my pc in good location with 4g mobile without fiber internet or whatever it is and its night and day difference. even the monitor quality and enemies movement are so smooth so its kinda related to electricity also.lulded wrote: β09 Feb 2022, 09:26The thing is, at least for me, my cable coax/ground is influencing my "EMI". If I remove cable/turn off modem, the better kits definitely feel more responsive.wadge wrote: β09 Feb 2022, 09:16I also came to the conclusion that there must be something to do with the ram like every time i start the game after the pc has been shut down for a day the first game is perfect in term of hit reg and stuff no delay but after that even if you reboot it reminds the same, desync and all that.
Same problem as me but: if i play at night (till 2.am to 7.00) all games run so much better. So the question is: something about internet congestion in my area? or something about electricity for the same reason? The only one thing in common is that at that time everyone is sleeping. I allready tried with 4g and stuff and it didnt change anything, and my main internet line is a vodafone 1gb fiber.Plznoinputlag wrote: β09 Feb 2022, 13:29i feel the same issue when i unplug the modem from the outlet its more responsive and tried to ply with 4g mobile internet the bad hitreg and prefires still there. i tried my pc in good location with 4g mobile without fiber internet or whatever it is and its night and day difference. even the monitor quality and enemies movement are so smooth so its kinda related to electricity also.lulded wrote: β09 Feb 2022, 09:26The thing is, at least for me, my cable coax/ground is influencing my "EMI". If I remove cable/turn off modem, the better kits definitely feel more responsive.wadge wrote: β09 Feb 2022, 09:16I also came to the conclusion that there must be something to do with the ram like every time i start the game after the pc has been shut down for a day the first game is perfect in term of hit reg and stuff no delay but after that even if you reboot it reminds the same, desync and all that.
How can be possible at late night everything runs smooth and hitreg is almost perfect? it must be something about congestion, thats why i think. But i dont rly know if is internet congestion or electricity congestion... Im going literally crazy about this problem since 2004.
I toke PC in other regions in my country and in some of them was night and day difference with my same PC.
Plznoinputlag
its electricity related bro. when everyone go sleep at night theres much less use of electricity. u can try turning of all your breakers except your computers room breakers and see if theres a difference.skkiNN wrote: β09 Feb 2022, 16:26Same problem as me but: if i play at night (till 2.am to 7.00) all games run so much better. So the question is: something about internet congestion in my area? or something about electricity for the same reason? The only one thing in common is that at that time everyone is sleeping. I allready tried with 4g and stuff and it didnt change anything, and my main internet line is a vodafone 1gb fiber.Plznoinputlag wrote: β09 Feb 2022, 13:29i feel the same issue when i unplug the modem from the outlet its more responsive and tried to ply with 4g mobile internet the bad hitreg and prefires still there. i tried my pc in good location with 4g mobile without fiber internet or whatever it is and its night and day difference. even the monitor quality and enemies movement are so smooth so its kinda related to electricity also.lulded wrote: β09 Feb 2022, 09:26The thing is, at least for me, my cable coax/ground is influencing my "EMI". If I remove cable/turn off modem, the better kits definitely feel more responsive.wadge wrote: β09 Feb 2022, 09:16
