I currently have a 3440x1440 75Hz SJ55W which is giving me issues. Given this monitor's "high" resolution, I am getting performance numbers at around 60-80 FPS, dipping to 30-45 in combat. Not only that, but the frame times I am getting in-game are horribly inconsistent when running at native resolution.
1080p and the PC specifications may seem like a weird pairing, but given that I almost solely (95% of the time) play Rust, I think going with a 1080p monitor would be best for smooth gameplay.
Now that I have my reasoning out of the way, I'll move on to monitor choice. I am looking for the "BEST" G-Sync 1080p high-ish refresh rate monitor; I say high-ish given that I can't reach FPS numbers higher than 144 99% of the time. I don't mind about the price limit and instead am simply looking for the best features for my use case.
It seems like a lot of 1080p monitors are more budget-focused or crazy high refresh rate focused (<240Hz), which don't match what I am looking for. Something to bear in mind is the minimum refresh rate for a lot of these G-Sync compatible monitors is 60Hz, which I will most likely see during hectic gameplay sometimes. https://www.nvidia.com/en-gb/geforce/pr ... ors/specs/
Currently, it seems like the MSI Optix MAG251RX fits my bill quite well (IPS, Good refresh rate, low response time, good colours), but I would love to hear your opinion. I'm slightly worried about this option, given that it does not have dedicated G-Sync hardware and is just G-Sync compatible, which may not be ideal given the variable frame rate.
