BlurBustersStrobeUtility & Xl2411Z v2 "Colors"
JMH
Post by JMH » 26 Jun 2014, 06:59
So today i received my xl2411z v2 monitor. Beats the xl2420te i had
Now i have installed BlurBustersStrobeUtility Running the follwing settings
Override Ticked.
Persistence 1.5ms
Crosstalk on 2nd notch up
Now i was wondering if anyone couild help me get some good color now?
GPU is AMD Asus DCUII R9 280
I have tried fiddling but cant seem to get things right.
Would appreciate any help
Thanks
Re: BlurBustersStrobeUtility & Xl2411Z v2 "Colors"
Post by Chief Blur Buster » 09 Jul 2014, 17:28
If you are using Windows 8, try the Windows 8 Calibration Utility.
Also go to http://www.lagom.nl/lcd-test ...
The best ones are:
1. Lagom Contrast
Adjust until you can still see all shades of colors while the blacks are the blackest, and the bright colors are at their brightness.
2. Lagom Blacks
Make sure black is as dark as possible, while still barely seeing the other blacks.
Of course, if you're tweaking for seeing higher gamma, then step 2 might need to be brightened quite considerably (high gamma) which will wash out colors, but bring out enemies in the dark during FPS gameplay.
