Input lag of eGPUs
thanossapiens
Input lag of eGPUs
Post by thanossapiens » 06 May 2022, 11:16
Do external GPUs always introduce input lag?
I found only one post about it https://shaneycg.github.io/razer-core-latency/, have there been any other tests?
There does seem to be lag if the signal is resent to the device instead of an external display.
Re: Input lag of eGPUs
Post by Chief Blur Buster » 06 May 2022, 17:30
thanossapiens wrote:
06 May 2022, 11:16
There can be indeed latency from the extra frame-transmission overheads. Transmission of uncompressed frames over ThunderBolt would be dependent on the resolution. An uncompressed 1080p 24-bit frame is 6 megabytes, and transferring (including overheads) probably takes about a millisecond in real-world USB-C / Thunderbolt 3 transmission.
There may be additional driver overheads. Best case would probably be something like under half a millisecond but could be as bad as a few millisecond (2-3ms) -- someone would need to test this. At high frame rates like 200 frames per second, the frame transmission overhead can become quite significant.
You've got lots of 2-way traffic with an eGPU, like texture transmission and then the backchannel of sending back completed frames for display on the internal display.
