800DPI VS 3200DPI Massive Difference!
MegaMelmek
Re: 800DPI VS 3200DPI Massive Difference!
Post by MegaMelmek » 30 May 2022, 00:27
Asus x570 f gaming
ryzen 5600x
rtx 3060ti
g skill 16G 3600Mhz
win 11
what i missing in these testing is impact on gaming because i am sure if DPI has any advantage pro player will be use it no mater what but they dont…
Just by moving mouse on desktop it take like 7% CPU use and thats on 800DPI 1000Hz how it went on 3200DPI for sure more than 7% so you can see that these test are not complex because they not made by gamers but probaly gear seller….
Vocaleyes
Post by Vocaleyes » 30 May 2022, 12:33
When my mouse allowed for the development of muscle memory, I was 1850dpi and 250 polling. Was always the best feeling for me.
SVSQUVSH
Post by SVSQUVSH » 31 May 2022, 13:39
Vocaleyes wrote: ↑
30 May 2022, 12:33
Sure, its all personal preference. 250 Polling rate has its pros too. Its lighter on your CPU which could give you smoother gameplay.
kokkatc
Post by kokkatc » 31 May 2022, 16:40
SVSQUVSH wrote: ↑
31 May 2022, 13:39
Vocaleyes wrote: ↑
30 May 2022, 12:33
250hz polling may net you extra fps, but it will only result in choppy gameplay. Why? Because the mouse is only polling 250hz when you actually move the mouse. I don't know if you ever tried 250hz, but your gameplay will be significantly more choppy due to the low polling rate. You would have to be an absolute potato of a machine not to notice the difference in visual smoothness from 250-500hz. You begin to get diminishing results at 500hz, but I can notice and feel the smoothness added by say 1000hz.
Vocaleyes
Post by Vocaleyes » 01 Jun 2022, 03:19
I preferred to use 250 polling over 1000 due to even when mouse allowed for development of muscle memory, 1k didn't feel "correct", in terms of mouse response/ fluidity. In terms of picture smoothness, I agree with you 100%, the higher the poll the smoother the video playback, but as it always has, each polling rate varies in terms of feel.
Also while there is certainly a difference in picture smoothness between 250 and 500 it's nowhere near as much of a hinderance as 125hz, THAT is unplayable in terms of visual clarity AND mouse response, however I would rather 30fps if the trade-off was a correctly tracking mouse any day of the week!
Also just to clarify, 500hz also allowed for muscle memory development when mouse tracking was consistent back in 2000 - 2016, and is completely fine.. I just preferred 250 over 500 due to 250 feeling like it had less of a restriction on the vertical axis.
Post by Chief Blur Buster » 02 Jun 2022, 16:40
Crossposted from other thread
02 Jun 2022, 17:43
History - 400dpi in older engines like CS:GO
This approach used to be more useful back with lower Hz, lower frame rates, and older engines -- especially if you're playing with only one competitive game -- but when frame rates and refresh rates went up, the pollrate and DPI needed to max-out your refresh rate benefit started to exceed the benefits of trying to optimize a low poll rate.
Playing at >240Hz with many newer engines now starts to show more benefits of the "high dpi, high poll, low sensitivity" approaches a lot more clearly, especially if you do at least some occasional eye tracking (part of the time) rather than stare-at-only-crosshairs approaches. It also scales better over multiple roles (e.g. switching in/out of sniper view)
Old mouse sensors were crappy at 1600dpi+ but this is no longer the case today. If you're using a new mouse with a good sensor, a clean mouse pad, clean mouse feet, and one of the newer high-DPI friendly games, you might be at a disadvantage at 400dpi-800dpi especially with newer 500+ Hz monitors
Newer Engines, Newer Sensors, Higher Refresh Rates Start To Change the DPI Calculus
Several newer sensors also make it easier to preserve muscle memory across dpi/poll settings (with proper calibration of sensitivity setting to compensate). A lot of sensors became more opaque on muscle memory of "magic DPI numbers", so it's now usually better to scale to a preferred sensitivity by tilting your DPI:sensitivity setting and train your muscle memory based on a preferred flick speed.
In several new engines, fast flicks at 800dpi/1sens feels much more identical to 3200dpi/0.25sens (scale numbers accordingly) than they did in older engines. 1600dpi has less issues than 800dpi though.
The magic of high DPI occurs during the slower flicks -- where 3200dpi/0.25sens looks much smoother than 800dpi/1sens allowing 4x higher framerate during slow tracking (e.g. like slow sniper sight hunting / tracking) without the coarse step-step feel. Slow mouse pans start to feel TestUFO-smooth rather than grainy steppy-steppy feel.
Low DPI Can Sabotage Frame Rate Of Your Mouseturns / Sniper Scope
If your grainy low-DPI sniper track was 20-50 stepped positions during slow tracking at 60Hz, or even just 100 steppy-steppys at 144Hz, it is not as noticeable as the graininess of the same tracking at 360Hz or 500Hz. You see, if your slowturn at low DPI is causing only 50 different mouse reports per second, that's only 50 frames per second in screen mouseturn panning position updates (mouseturn). 50fps-vs-60fps is not as easy to notice as 50fps-vs-360fps.
Although enemies move at full frame rate at all times, the horizontal/vertical movements (mouse turn, sniper scope) can feel steppy-steppy especially if you're trying to do tiny amounts of tracking (e.g. moving a few pixels at a time).
Many do train to blindly shoot after a flick, using pure muscle memory alone without visual-feel as part of your muscle memory. Then congratulations, you trained on a DPI-independent approach and you can safely increase DPI in Valorant/Fortnite with newer sensors that feels much more same at 400-800-1600-3200 at scaled sensitivities. In this case, Pass GO, collect $200, and adjust your mouse settings a little, retraining for any minor differences. The best sensors in the best hi-DPI aimtrainers (not aimtrainers based on old engines like CS:GO), should feel much more identical (than they used to) at all DPI settings (sensitivity scaled) if your muscle memory was trained differently this way.
But if you're visually tracking, then that's where problems tieing you to 400dpi begin. You've just slightly sabotaged your skill portability to 360Hz-500Hz monitors and newer engines. 240Hz-vs-360Hz is also sometimes sabotaged by low DPI, and can cause people to downgrade to a lower Hz that feels better with low DPI.
The mouse begins to sabotage the Hz of the newer ultra high refresh rate monitor, and those 3200dpi new-engine-only players with new ultra high refresh rate monitors start to take a few points this year, more points next year, and so on, away from a optimized-magic-DPI rig that worked so well in the lower Hz days.
Such optimized 250-500dpi rigs start to be overwhelmed by the other players' refresh rate advantage in a "high poll + high dpi + low sensitivity" approach now recommended with newer game engines (i.e. you're not only playing CS:GO). The players that train with the "high poll + high dpi + low sens" approach starts to produce better results now. The esports champions that are now using 240Hz monitors + 1600dpi are a great example of this.
Obviously higher DPI is more sensitive to weak links (e.g. game engine based, mouse pad based, mouse feet based, mouse sensor based, dirt, etc) so keep things as good as you can if you want the silkiness of high-DPI tracking to "keep up with the refresh rate race".
More Professionals in Esports Recognizing Higher DPI Benefits In Newer Engines
The game engine and its mechanics with high-DPI can vary a lot in the professional leagues -- so sometimes you want to train with settings everyone else is using. If nobody is using 3200dpi in Valorant, then you can still have an advantage with an optimized magic-DPI system. But as more and more players start to migrate DPI usage in games that are friendly to high-DPI, this can change.
It's all over the map, though. On sites like prosettings.net, you see many CS:GO players use still 400dpi but a lot of LoL players use 1600dpi-3200dpi. Almost nobody is using less than 1600dpi in LoL though -- but it's still relatively rare in Valorant (which feels more high-DPI friendly than CS:GO).
Be noted prosettings.net sometimes is more than a year behind for some teams that gave stale data (e.g. pre-Razer-8KHz) so some players have already increased DPI in some FPS games like Valorant and Fortnite, once they finally figured out that those engines are more high-DPI friendly than CS:GO ever was. Far more Fortnite esports teams use ~1000 to ~4000dpi Fortnite than in CS:GO, even though many still stick to 400 & 800.
Low DPI Coarseness Was Visual Cue In Classical Muscle Memory Training
(Especially when refresh rates were lower)
CS:GO has less precise mouse coordinate mathematics than Valorant and Fortnite does. Preserving visual muscle memory from CS:GO can also be a factor (even the steppy steppy feel of low frame rate may be important, like mentally feeling the number of frames clicking during a tiny slew of a sniper scope).
The frame-rounding effect of a low framerate, may be able to snap-to-pixel more precisely on tiny distant enemies, if you've trained your muscle memory visually on the steppy-steppy feel of low DPI. Low DPI is sometimes kinda like ruler if you use the visual frameratefeel of a slow short-distance flick or sniper scope slew, as part of your muscle memory training. In keeping DPI numbers really low in other FPS games, as a matter of habit -- transitioning to Valorant and Fortnite from CS:GO is muscle-memory-easier at 400dpi-vs-400dpi.
CS:GO mousefeel definitely feels more different 400-vs-800-vs-1600 (sensitivity scaled appropriately) than it does in Fortnite/Valorant. The same distance flick doesn't scale as consistently as it does in newer engines with better floating-point mouse mathematics.
Low DPI During Slow Slew (e.g. Sniper) adds More Latency Disadvantage During Competing With 360-to-500Hz Hi-DPI Players
The steppy steppy behavior adds input latency. When you are mouseturning at only 20 kliks (mouse coordinates) a second, you might have 1/20sec latency during your slow sniper slew. Ouch. This is fine for 60Hz with 1/60sec latency when the advantages of the muscle memory benefit of the grainyfeel outweighed the latency of low-DPI. Especially since CS:GO was so ultra-heavily optimized at 400dpi and 800dpi
However, the latency reductions of "high dpi, high poll, low sensitivity" on new ultra high refresh rate monitors, now massively outweigh the old-fashioned muscle memory training technique. If you spent 10 years at 400dpi, it will be tough to transition, especially since 10 years is often longer than most esports careers. But, not everyone fits into this, and can easily re-train.
If your aimtrainer app is based on Source engine (same as CS:GO) then the aimtrainer is possibly only 400-800dpi friendly because it uses the less accurate mouse mathematics of the older Source engine. So you have a training problem too; if you use an aimtrainer to retrain to high DPI, stick to newer aimtrainers that are high-DPI friendly, or use one based off a high-DPI-friendly game engine.
New Players Who Go Straight To Newer Engines (Skipping Old Engines like CS:GO)
But as more new players who's never played CS:GO enter esports directly into newer higher-DPI-friendly engines (Valorant, Fortnite, and others), is more likely to be more comfortable going straight to higher DPI approaches, where the pros can outweigh the cons if your refresh rate is high enough. With refresh rate stratospheres involved, there are additional gaming tactics that benefit from the "high DPI, high pollrate, low sensitivity" approaches.
Also, the longer mouse travel distance required to keep low-DPI approaches low latency, starts to fail against high-DPI players in good-high-DPI-compatible engines, who can physically move their hands only a medium distance (e.g. two inches instead of ten inches) to do their own differently-muscle-memory-trained flick, allowing a frag sooner than the longer flick distances required for low-latency low-DPI.
Other players don't need to retrain for different flick distance. They can easily scale sensitivity settings for exactly the same flick distance at 400-800-1600-3200 (or intermediate numbers like 2000 etc) -- new sensors, clean mouse feet and clean mouse pad lets you do that in newer high-DPI-friendly engines. So less muscle memory concern. So fewer or zero aim-retraining compromises for these players.
Also, real life frame rates and real life snipers don't have the existence of a "coarsefeel" muscle memory training tricks, so are thus more real-life realistic, for real-world shooting versus virtual shooting. Even though Fortnite is fantasy, Valorant is less so, and some games are more shooting-simulator. This can be relevant, since coarsefeel is an artificial muscle memory training trick only enabled by a finite frame rate and a finite refresh rate -- but real life has no frame rate or a low-DPI coarsefeel to train from.
The ever-higher refresh rate however tips the domino of a fence-sitter who's unsure of whether or not to go above 800 dpi, especially if they decide to discontinue playing in any of the legacy engines. If you're already a low-DPI high-sensitivity player, it's easier to transition to high-DPI low-sensitivity, because there is not always enough decimal digits in the sensitivity sliders.
Game Developers: Use 3 Decimal Digits in Sensitivity Sliders For Easier Transition Training
Blur Busters recommends game developers to use at least 3 decimal digits in sensitivity settings, to allow easier division -- e.g. 400dpi @ 1 sensitivity translates to 3200dpi @ 0.125 sensitivity. If you can only choose 0.1 or 0.2 then it's much harder to transition to 3200dpi from 400dpi.
Simple workarounds:
- You can keep your UI simple (0.1 steps), but at least allow your gamer to edit the configuration file to add decimal digits as needed
- You can let users click the sensitivity number to manually edit it, instead of slider the slider.
- Etc.
Please make sure to also additionally QA test your game with 1000dpi-4000dpi+ esports players, who have increased massively in numbers in the last few years. Also recruit newer-blood esports players who's never played CS:GO, for a more accurate vet of your high-DPI friendliness of your engine. You need to test all types of esports players too.
If you are designing or improving your game engine, use double instead of floats for scaled mouse coordinates -- to preserve maximal precision when calculating mouse coordinate mathematics. There are situations where math rounding errors can build up -- with an 8000 Hz poll rate mouse, 8000 math roundoff errors per second of a "float" accumulator instead of "double" accumulator, can spike up to human visible pixel-offset misalignments. Also, performance of doubles is identical to float on most modern computer systems, especially since you're not doing any more than 8000 sets of mouse mathematics per second anyway. It's not like a GPU doing billions of math calculations per second -- you can afford to preserve a double accumulator (not float) for 8000 accurately-microsecond-timestamped mouse deltas per second, that's virtually zero impact on performance -- just cast to a float at the final step if your rendering of new mouseturn position requires floats.
At 60Hz using a 125Hz mouse, fewer mouse math roundoff errors occured. But at 500Hz refresh rate and 8000Hz mouse, especially when multiplied by a sensitivity factor, can generate enough math rounding errors occurs in one second (in floats) to create full-integer pixel misalignments! This can make it worth transitioning your game engine to use doubles for all mouse mathematics. Also keep it as high precision for as long as possible when accumulating mouse coordinate math over a longer time period.
In designing your game engine, keep it sub-pixel accurate between adjacent polls as you can, because it adds up to many pixels of error over a long flick. Many GPU APIs use floats, but you need to keep mouse coordinates accumulated in doubles across a long time period, and only cast-off to floats or integers as needed at the last minute (e.g. passing along to an OpenGL or DirectX API etc). This is part of the reason why 3200dpi works so much better in Valorant/Fornite than it did in CS:GO. We already cover this problem in High Definition Mouse API.
But What About Turbo Mouse Cursors? Any Fix For Too-Fast Cursors?
This is a known problem, so you have to use your mouse profiles or DPI button to lower your DPI when exiting to Windows. If your game involves large amounts of inventory menus, then hopefully you can adjust your pointer speed setting without interfering with the DPI of other things.
Ideally, I recommend 3 separate sets of sensitivity settings for FPS -- a pointer sensitivity setting, a sniper scope sensitivity setting, and a mouseturn sensitivity setting (and X/Y axis where applicable, as some games use separate sensitivity settings for different axes). In some cases, if the newer engine is using rawinput and the pointer is using old mouse APIs, you can use the Windows sensitivity setting (but disable Pointer Precision checkbox). This is safe for certain FPS/RTS games so you can keep your pointer speed unchanged when increasing mouse DPI.
However, older games (like Warcraft with rawinput disabled) didn't use rawinput for mouseturns, so be careful adjusting your pointer sensitivity setting if you have a lot of games installed. Just two years ago, Quake Champions wasn't even using rawinput, but a recent patch has transitioned it to rawinput. If all your games are rawinput-compatible, it becomes safe to adjust the Windows Pointer speed setting in Control Panel to slow down your mouse pointer while increasing DPI -- since it no longer interferes with your mouse turns in games, but helps your mouse pointer in inventory screens, etc.
In the longer term, a future HD Mouse API could fix this problem permanently.
About one-third of the Faze clan now use at least 1000dpi+ in Fortnite!
The old adage that esports athletes never use more than 400dpi-800dpi in FPS is becoming outdated. It was useful for CS:GO (and transitioning from CS:GO) which is super-heavily optimized at 400-800dpi, but newer engines are now high-DPI friendly.
As refresh rates go up, the benefits of using "high dpi, high poll, low sensitivity" starts to exceed other muscle memory training techniques on former coarsefeel techniques that had other issues (e.g. increased latency caused by fewer mouse coordinate reports per second during low dpi approaches).
SVSQUVSH
Post by SVSQUVSH » 03 Jun 2022, 13:43
Thank you Chief for this interesting insight into the DPI Theme! Learned some new things too. So, I will definetely stay on high DPI depending on the game etc.
xPrzybyLx
Post by xPrzybyLx » 04 Jun 2022, 16:35
For me the difference between 800dpi and 3200dpi (current) is very noticeable.
The movement when using 3200dpi is so smooth and precise especially with FreeSync=On + Vsync=On.
