News on the ROG Swift (PG278Q)
Papagaj
Re: News on the ROG Swift (PG278Q)
Any news ?
I guess EU release should be late July and US early August... is my guessing correct guys ?
- GameLifter
Papagaj wrote:Any news ?I guess EU release should be late July and US early August... is my guessing correct guys ?
It's hard to say. According to the facebook post by ASUS, pre-orders may begin in early August so that could mean they won't get here until late August. As for EU, they've had pre-orders open on some sites so late July may be correct.
SandroX
Q83Ia7ta
They finally did it!
- RealNC
Awesome. The monitor's performance looks good. Well, at the price they're selling the thing, it better be
According to TFT Central, the colors are excellent for a TN. But I don't see them mentioning anywhere at what refresh rate they did the color tests. If they got these results in 144Hz, that would be mighty impressive. But somehow I suspect those are the 60Hz results?
- masterotaku
I'm impressed. The monitor has a strobe lenght setting in the OSD. At 120Hz, it ranges between 0.25ms and 1.875ms. There are three overdrive settings: off, normal and extreme. Looking at the overshoot data, the normal mode seems better than BenQ's AMA. Unfortunately ULMB only works at 85, 100 and 120Hz. If it worked at 60Hz, I would consider buying it in the near future.
Monitor: Asus PG278QR
Vega
60 Hz strobing would be unusable for the vast majority of people. Way too noticeable flicker.
My largest disappointment with the screen is the low cd/m2 brightness in ULMB mode. Pretty much have to keep it at 100% pulse duration and 100% brightness just to get a usable for gaming 120cd/m2. All those super fast pulse duration (and epic motion clarity) will be too dim to use.
Vega, 60Hz strobing is still a useful option to be available - not everyone needs to use it. It is usable for consoles at slightly farther view distances (2:1 ratio view distance relative to screen width) where flicker becomes less of an issue. It should be a choice that exists, even if not everyone uses it.
Re-Tweeted and blogged our friends at TFT.Q83Ia7ta wrote:They finally did it!
http://www.blurbusters.com/tftcentral-r ... ightboost/
Strobe length adjustable
All the way down to 0.25ms.
Vega
Ya Mark, was so excited to see those super quick strobes. Well until I saw that associated luminescence levels lol. Should be a killer monitor for motion clarity though in a pitch black room.
Any speculation on what a .25 to .5 ms strobe should do for motion clarity? That's even faster than a phosphor rise and fall time and make it the clearest display ever (albeit very dim)?
