Z690 usb/timer issue
Re: Z690 usb/timer issue
Post by Slender » 06 May 2022, 19:15
alright, after tests, i see 0.4966 timer res cause unsmooth gameplay, after restart timer take 0.4999 or 0.5 and feel good.
Post by Slender » 28 May 2022, 11:44
1ms vs 0.5ms
deletevalue tick/clock
kokkatc
Post by kokkatc » 31 May 2022, 16:53
Slender wrote:
28 May 2022, 11:44
1ms vs 0.5ms
It was my understanding DPC latency checker does not work on any OS newer than Windows 7. You would have to use latency monitor. Are you on windows 7 or other?
xdropz
Post by xdropz » 01 Jun 2022, 12:14
could you guys please elaborate why rtc source timer is better than acpi ?
Post by Slender » 01 Jun 2022, 14:30
xdropz wrote:
01 Jun 2022, 12:14
i dont know, acpi better on z690 for me.
rtc cause strange mouse movemient and lag.
but on z390 rtc by def and feel different
Post by Slender » 01 Jun 2022, 14:31
3 different timers on z690, takes randomly after reboot
xdropz
Post by xdropz » 02 Jun 2022, 06:22
i dnt need to reinstall the whole os? I just need to use grub and change the setting in bios ?
Post by Slender » 02 Jun 2022, 18:48
xdropz wrote:
02 Jun 2022, 06:22
yes, just use grub.
Post by Slender » 02 Jun 2022, 23:06
kokkatc wrote:
31 May 2022, 16:53
Slender wrote:
28 May 2022, 11:44
1ms vs 0.5ms
win10. latency monitor is latencymon?
tinkiy4333
Post by tinkiy4333 » 03 Jun 2022, 05:41
Slender wrote:
02 Jun 2022, 18:48
xdropz wrote:
02 Jun 2022, 06:22
yes, just use grub.
how can i change hidden bios settings with grub?
i dont find any information on google. i want disable hpet in bios
