Sounds good to me, I might give you a better advice if you can tell me how many fps you generally get while playing Valorant.
- axaro1
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
hardt
- axaro1
240hz OD60 is good enough for your setup, alternatively you could use 280hz + Adaptive Sync ON + OD60 + 275fps cap, you'll get some minor latency improvements.
If your fps were in the high 270 I'd recommend OD120.
*= currently owned
*= currently owned
hardt
jeksonmatri
@axaro1
Hello, can you advise the settings for apex when my average fps is around 200 and in melee it sits up to 150
- axaro1
Adaptive Sync ON with OD 60, ELMB-Sync OFFjeksonmatri wrote: ↑02 Jun 2022, 20:22@axaro1
*= currently owned
*= currently owned
Doonikh
Hello everyone, help me choose the settings for CS:GO, my average FPS is 350-400. I also read your article yesterday, and I didn't understand how to make 10 bits for 280 Hz. Thanks !
jeksonmatri
@axaro1 Thanks, should I use 240 or 280hz with overdrive 60?
Henkkq
Hi!
I need help. Cant find sweet spot for my 259qm
I usualy play warzone with fps around 150-100
Pc 5700xt red devil oc, 5 3600x
Best settings for the vg259qm?
elcz1
Hi. First I want to say thank you for all information and advice shared here!
After seeing different settings recommended to different context I'm a bit confused what exactly I should be using
I appreciate any help someone could give me. I'm playing mainly Valorant and osu!, on osu! I can get 900+fps no problem, Valorant on the other hand I'd peak at 240~270 fps in The Range looking at bots but during actual matches my fps will be fluctuating 180~250 sometimes getting as low as 140~150 if there's too much happening at once.
I'm using Ryzen 5 2600 as CPU and RX580 8gb as GPU
Thanks!
Thanks!
