Can't get my XL2546 to be smooth
peak
Post by peak » 24 Apr 2022, 10:35
For the past few months I've gotten into competitive Apex Legends almost getting Master after a week of playing, but I always feel inconsistency when it comes to the smoothness of the game. I have an XL2546 with DyAc enabled and AMA set to Premium, I did mess around with Strobe Utility, but I don't like the idea of tweaking things in that way since I feel more comfortable knowing what it's actually doing.
I reformated my PC, I'm running relatively stock settings on my motherboard which is fitted with a Ryzen 5600x, 3600mhz 32gb cl18 ram and an RTX 3060. DOCP and Resizeable BAR is the only thing really enabled.
What I'm here to ask about is, how come everytime I factory reset my monitor the monitor seems to be smooth until restart, it goes back to feeling a little odd?
I religiously play competitive games, and I'm skilled at Apex Legends, but these days most games just don't feel like they allow me to play the way I want to play, in my case I feel like it's tunnel visioned.
Thanks in advance.
Illuxzaah
Re: Can't get my XL2546 to be smooth
Post by Illuxzaah » 18 Jun 2022, 03:04
Hey mate, interestingly and unfortunately this has happened to me too. Have you found a fix? I tried resetting with CRU but even that didn’t help. Sad nobody else commented on this would be great to see some inputs on this one.
Asus VG248QE, Dell S2721DGF, Samsung Odyssey G7 27”, Viewsonic XG2431, XL2546K, MAG251RX, XL2566K.
7800x3D, 7900XTX. Currently on 2556k ama 21, best monitor I have ever used. Waiting for 1440p 360hz (OLED or Zowie)
Shade7
Post by Shade7 » 19 Jun 2022, 14:20
Does a GPU driver reinstall/update give the same smoothness as factory resetting for you?
Curious- since I have noticed this kind of strange inconsistent behavior with high refresh rate monitors before.
daviddave1
Post by daviddave1 » 20 Jun 2022, 07:47
Is Apex in exclusive fullscreen ? So when u press the mute button on your keyboard u don't see the windows mute button layover pop up ingame? If u see the mute button follow
https://www.youtube.com/watch?v=E4WbtrV ... LOBOTOMYtv
| Now: ASUS PG248QP 540Hz. | Past : VG259QM with the Qisda panel/PG27AQN/XL2566K
Djbluebricks
Post by Djbluebricks » 24 Aug 2022, 12:51
Try dyac off, fps cap 240, 16x anti, ama high or off,( I just found out off is better for me), 2gb ram, no over clock on gpu. Nvidea graphic settings to performance
I’m currently cruising through plat 2 br.
