MTU packet loss
Plznoinputlag
MTU packet loss
Post by Plznoinputlag » 10 Jul 2022, 13:32
Hello guys my isp MTU size is 1500 but its 100% loss when i checked with cmd but when u reduce it to 1450 i dont get loss but the problem is when u configure your mtu to 1450 or whatever number that dont give you loss its became the same with 100% loss.
what to do?
Xehet
Re: MTU packet loss
Post by Xehet » 10 Jul 2022, 13:58
It might be easier to simply use TCP optimizer to find the correct MTU value.
Shade7
Re: MTU packet loss
Post by Shade7 » 10 Jul 2022, 15:37
How do you check this with CMD?
Just curious. Wanted to try it myself.
Unreazz
Re: MTU packet loss
Post by Unreazz » 10 Jul 2022, 16:38
This is because of IP Header noo ? if youre MTU is 1500 than you have to add -28 i think to it and need to place it on 1472
Plznoinputlag
Re: MTU packet loss
Post by Plznoinputlag » 11 Jul 2022, 05:50
Unreazz wrote:
10 Jul 2022, 16:38
yeah when i downgrade the value to 1450 its 0 loss but when u apply the 1450 its giving loss on 1450 value. and then when u go lower 1400 its 0 loss but when u apply it its giving 100 loss even in 1400 and goes on very confusing
Plznoinputlag
Re: MTU packet loss
Post by Plznoinputlag » 11 Jul 2022, 05:51
Xehet wrote:
10 Jul 2022, 13:58
the correct value doesnt matter in this case because whatever number you apply its always giving you 100% loss.
