Also, I couldn't tell from watching the Henry Linn video on nVidia's website which ports got eliminated by the upgrade. Will I still be using my DVD-D cable? It looks like the only port available is HDMI...
Has anyone tried Assetto Corsa?
Cooknn
My new G-Sync board will be here tomorrow
Hoping it works okay with my primary title, Assetto Corsa. The game allows us to select our resolution/refresh rate in game. Currently running 1920x1080@144Hz. Just a little concerned that it remains locked at whatever I select. Is there something like Fraps that I can see while in game that will show what my refresh rate is? The game has an fps indicator built in.
Intel Core i7-4790K @ 4.7Ghz • 2 * ASUS GeForce GTX 780 Ti DirectCU II • Asus VG248QE Monitor w/ G-SYNC • Corsair Obsidian 450D Case • Asus Sabertooth Z97 Mark 2 Mobo • Corsair H100i CPU Cooler • 16GB Corsair Vengeance Pro SDRAM • Windows 8.1 64-bit
flood
Re: Has anyone tried Assetto Corsa?
If you're running with gsync, it will show Mode GSYNC when you press the menu button. To see and check the instantaneous refresh rate, yes you need fraps or something similar.
The only remaining ports after the upgrade are displayport and power. The kit comes with a displayport cable. Your card has displayport so don't worry.
offtopic: what voltage is your 4790k at? are you running all four cores at 4.7ghz?
Cooknn
Thanks for the quick reply, flood! I'm running 1.295V and all four cores are rock solid at 4.7GHz. I initially thought I'd use 4.8 (1.315V) but even though I pass the stress tests it gets too hot for a 24/7.
- sharknice
With the latest version of geforce experience and shadowplay you can display the FPS without recording, similar to FRAPS.flood wrote:If you're running with gsync, it will show Mode GSYNC when you press the menu button. To see and check the instantaneous refresh rate, yes you need fraps or something similar.
Cooknn
Thanks, sharknice
Do you know of a way to check the refresh rate of my monitor while in game?
- sharknice
If you're using the GSYNC kit it will tell you if you press the menu button on the monitor.Cooknn wrote:Thanks, sharkniceDo you know of a way to check the refresh rate of my monitor while in game?
Cooknn
It will give me dynamic refresh rate? I just want proof that it's actually working in my gamesharknice wrote:If you're using the GSYNC kit it will tell you if you press the menu button on the monitor.Cooknn wrote:Thanks, sharkniceDo you know of a way to check the refresh rate of my monitor while in game?
- sharknice
Nope. It will just tell you the maximum refresh rate if GSYNC is active, or the current refresh rate if it is off.Cooknn wrote:It will give me dynamic refresh rate? I just want proof that it's actually working in my gamesharknice wrote:If you're using the GSYNC kit it will tell you if you press the menu button on the monitor.Cooknn wrote:Thanks, sharkniceDo you know of a way to check the refresh rate of my monitor while in game?
But I would assume whatever the frame rate shadowplay is giving you is what is being sent to the monitor.
PoWn3d_0704
Cooknn wrote:My new G-Sync board will be here tomorrowHoping it works okay with my primary title, Assetto Corsa. The game allows us to select our resolution/refresh rate in game. Currently running 1920x1080@144Hz. Just a little concerned that it remains locked at whatever I select. Is there something like Fraps that I can see while in game that will show what my refresh rate is? The game has an fps indicator built in.
I play the hell out of Assetto Corsa! Works GREAT! There seems to be a bit of engine based stutter when there is a lot of smoke though. Other than that, GSync is smooth sailing. I play anywhere from 90-144 fps normally and Gsync has been working flawlessly.
Asus VG248QE with GSync. Blur Busters GSync Contest Winner.
Cooknn
SWEETPoWn3d_0704 wrote:I play the hell out of Assetto Corsa! Works GREAT! There seems to be a bit of engine based stutter when there is a lot of smoke though. Other than that, GSync is smooth sailing. I play anywhere from 90-144 fps normally and Gsync has been working flawlessly.
Launch Options (in Steam): -cpuCount=4 -exThreads=7 -high
