Weird phenomena related to audio resulting in less input lag/delay
assombrosso
Post by assombrosso » 07 Sep 2022, 20:02
I have sennhieser headphones which comes with these parts
https://www.google.com/aclk?sa=l&ai=DCh ... g96BAgBEEQ
I didn’t connect my headphones well to my mobo, the jack wasn’t all the way inside the mobo line out port, you could still hear the sound but it was low/muffled and it made csgo a lot smoother in hit reg/mouse, yes, I tested twice, taking the headphones out didn’t help, but having them half way in where they are recognised by the pc but not all the way in, you can hear low muffled sound made my game and control alot faster, what’s the reason behind this? You can try it and see if it makes a difference.
From reddit:
“Basically what happens is you disconnect the ground channel of the headphone jack, while leaving the left and right channels connected. A circuit is formed between the two left and right pins, with both speakers in between, and you hear the difference of the two channels (which basically filters out anything that is the same in both). Here are some circuit diagrams which might make this clearer: http://imgur.com/a/t3vhE:
Also:
“ Basically, what you're experiencing is phase cancellation. The R+ conductor of your headphones is contacting the negative of the output, while the L+ conductor of your headphones is contacting the R+ of the output. The negative of your headphones probably isn't contacting anything at this point, so the R+ and L+ are referencing each other rather than the negative, so the resulting audio wave is the difference between the left and right channels, which is basically just whatever has a phase difference between the left and right channel. If you played a mono track you probably wouldn't hear anything.
Edit: a similar effect could probably be achieved by duplicating a track and inverting it's polarity, then slightly time shifting one of them or EQing one of them differently than the other.”
Try to plug it halfway in or 3/4 less or more until you achieve the required outcome. I’m not making this up, I actually noticed my mouse became laggy/icy when I plugged my headphone jack all the way in.
Bobo
Re: Weird phenomena related to audio resulting in less input lag/delay
Post by Bobo » 08 Sep 2022, 10:04
you might have a ground loop somewhere.
cybepine
Post by cybepine » 08 Sep 2022, 13:21
This may not answer your question directly but I will put this here as you have these kinds of problems.
I have been reading (from different places) and thinking a lot of these "things" lately.
The key here is this:
Circuits (e.g. computers) are constantly measuring logic voltages against the "zero voltage reference" of safety ground. This could explain why reinstalling system (Windows) works for a while and then the lag comes back. And also why it changes with time of the day.
So what could be cause of this?
Neutral to ground voltages or more like differences of it. The difference in voltage between the neutral to the ground should be less than 1 volt.
You can measure this easily with multi-meter or voltmeter from outlet. If you have never before measured live wires, you should be careful. Make sure you measure the neutral wire and not hot!
You can measure this different times of the day to see if it correlates with the lag.
The wires in our houses are basically antennae and will pick up any RF or static electricity and carry that.
https://esgrounding.com/blog/how-we-can ... ransformer
I attached a paper that explains the matter better.
Yes, old paper but the information is still correct.
And ferrites may help (75/J MnZn 150 KHz – 10 MHz).
A note must be made, I don't yet have this "thing".
Neutral-to-Ground-Voltage-Causes-and-Cures-White-Paper-202.pdf
(616.72 KiB) Downloaded 209 times
wadge
Post by wadge » 14 Sep 2022, 10:51
Something that also may be related : https://www.overclock.net/threads/heads ... s.1746166/
