DP Cables
Dzekson22
Re: DP Cables
Post by Dzekson22 » 09 Sep 2022, 10:08
I have dp and I show 2.7 gbps, what does it depend on?
Nawafwabs
Re: DP Cables
Post by Nawafwabs » 09 Sep 2022, 18:30
Dzekson22 wrote:
09 Sep 2022, 10:08
what your max and current link rate ?
resolution ?
SeekNDstroy
Re: DP Cables
Post by SeekNDstroy » 09 Sep 2022, 22:17
Nawafwabs wrote:
09 Sep 2022, 01:42
SeekNDstroy wrote:
08 Sep 2022, 22:53
Pardon me, im using latest gpu-z with an amd gpu with hdmi on LG 24gl600f. I dont see any monitor info(5.1gbps / 8.2gbps! ) on my gpu-z ? Is this DP cable or Nvidia specific option only? Thanks.
Hi, i saw this pic on internet already. But mine ended at adjustment area. No monitor tab.
After some search, i found that in adrenaline software, HDMI link status monitoring is disabled. Couldn't find anything to enable it. I guess for this its not showing on gpu-z.
Shade7
Re: DP Cables
Post by Shade7 » 10 Sep 2022, 19:13
The new cable just arrived.
Mine still says 5.4 Gbps current & max. Not sure what I was expecting, but for $15 bucks, I'm in. Seeing if I feel any difference during gameplay anyways.
GPU: 1080Ti
Monitor: ASUS VG258QM 280Hz
Ragerlis
Re: DP Cables
Post by Ragerlis » 10 Sep 2022, 21:56
Shade7 wrote:
10 Sep 2022, 19:13
GPU: 1080Ti
1000 series need a firmware update for 1.4 speeds, if you dont, 5.4 is the expected max speeds.
roro13200
Re: DP Cables
Post by roro13200 » 11 Sep 2022, 04:59
I have a 3000 series and yet the speed is limited to 5,4.
Tuhin Lavania
Re: DP Cables
Post by Tuhin Lavania » 11 Sep 2022, 06:09
I have a 3080ti and it shows 8.1 in both. ive ordered the cable, i dont have any hopes though.
Nawafwabs
Re: DP Cables
Post by Nawafwabs » 11 Sep 2022, 10:42
roro13200 wrote:
11 Sep 2022, 04:59
If you play on low refresh rate it's normal
roro13200
Re: DP Cables
Post by roro13200 » 11 Sep 2022, 16:22
hello
no i have a 240hz
Kanipshun
Re: DP Cables
Post by Kanipshun » 12 Sep 2022, 18:47
roro13200 wrote:
11 Sep 2022, 16:22
hello
no i have a 240hz
5.4 is DP 1.2 and there is no way you could run 240hz at DP 1.2 from my understanding. Is your refresh actually set at 240hz?
