Separate area for niche lag issues including unexpected causes and/or electromagnetic interference (ECC = retransmits = lag). Interference (EMI, EMF) of all kinds (wired, wireless, external, internal, environment, bad component) can cause error-correction latencies like a bad modem connection. Troubleshooting may require university degree. Your lag issue is likely not EMI.
Please read this before entering sub-forum.
cybepine
Post
by cybepine » 22 Sep 2022, 02:00
MegaMelmek wrote: β21 Sep 2022, 13:28
yesterday i was trying iron (2600W) in same outlet as my PCβ¦. it was best gaming session in long timeβ¦.
I think this test can be deciding factor for new ppl with input lag they can exclude internet and HW issue
Just want add all my cables are coper cca 8yoβ¦.
Indeed, cheap and easy way to test.
Examples of linear load devices include:
-Incandescent lighting
-Resistive heating elements
-Power factor improvement capacitors
-Transformers
-Motors
Here is a interesting video
Can I increase my linear load to cancel my harmonics?:
https://www.youtube.com/watch?v=CFDC4_Hayr0
Adding linear load does not decrease voltage harmonics. I though it would, seems I was wrong. It did however decrease current harmonics.
cybepine on 22 Sep 2022, 04:24, edited 1 time in total.
gadpaw
Post
by gadpaw » 22 Sep 2022, 03:48
mb active filter help, but they use for industrial.
(exists "small" version AHF 75A 230V sinexcel, but not found price ...)
ofc exists simple chinese variant, but i'm not sure about their the quality
skkiNN
Post
by skkiNN » 22 Sep 2022, 06:11
What about If i have PC and monitor connected to a good power strip? Should i try insert iron there and check if situation gets better? Or i MUST insert it on the outlet wall?
cybepine
Post
by cybepine » 22 Sep 2022, 06:57
skkiNN wrote: β22 Sep 2022, 06:11
Better just plug it to the outlet wall. I have made some calculations based on different models of irons.
cybepine on 22 Sep 2022, 08:10, edited 1 time in total.
skkiNN
Post
by skkiNN » 22 Sep 2022, 07:02
cybepine wrote: β22 Sep 2022, 06:57
Should be fine, just make sure to insert it before PC and monitor.
did you mean insert it before switch ON pc and monitor bro right? sorry but my english is quite horrible
skkiNN
Post
by skkiNN » 22 Sep 2022, 07:05
Basicly i need to insert iron on the same power strip, then switch on it, then switch on monitor and pc right?
cybepine
Post
by cybepine » 22 Sep 2022, 07:37
-delete
cybepine on 22 Sep 2022, 08:11, edited 1 time in total.
assombrosso
Post
by assombrosso » 22 Sep 2022, 08:02
cybepine wrote: β22 Sep 2022, 07:37
Sorry for the misunderstanding. I meant this:
Without X insert iron here. But first you should calculate current, that it does not take too much current, just in case.
which iron do you recommend buying, there are so many different ones, can you link me one ? also what do you think about toroid rings ? should i get those?
cybepine
Post
by cybepine » 22 Sep 2022, 08:14
I don't have any advice for that but safer to try first with incandescent lighting. I would suggest smallest wattage irons.
You will save money if this works, so toroid rings may not be necessary.
MegaMelmek
Post
by MegaMelmek » 22 Sep 2022, 09:54
assombrosso wrote: β21 Sep 2022, 17:25
MegaMelmek wrote: β21 Sep 2022, 16:52
assombrosso wrote: β21 Sep 2022, 16:13
Did I last for along time or got degraded ?
did not degraded yet and i hope it will not..... based what that Russlan guy says it will stay ok. Its kinda wierd run iron with 2600W all the time but i dont care for now.. At least i have prove that something is wrong with electricity not with all these windows tweeks, ISP, HW and so on...
I heard someone say even a heater plugged to the same circuit can act as a soldering iron, which iron did you use? Can you send me a picture. Hopefully it stays that way
i have like 8 way outlet splitter that is connected to the wall socket. In that 8 way splitter is connected everything include router monitor PC, iron. I think this way will help anything which draw lots of power but im am sure thats not soldering iron.... that can pull only like 400W
- IMG_1142.jpg (812.46 KiB) Viewed 5854 times
- IMG_1141.jpg (791.59 KiB) Viewed 5854 times
