How to target the CPU in gaming benchmarks
daninthemix
Post by daninthemix » 29 Sep 2022, 01:01
What is the correct way to target the CPU in gaming benchmarks? Set everything to Ultra and run at 720p to eliminate GPU?
I want to do some tests and see whether ECO mode on my 5950x makes any difference to frame-rates, so I thought I'd run a few games with benchmarks.
Kyouki
Re: How to target the CPU in gaming benchmarks
Post by Kyouki » 29 Sep 2022, 04:52
Awful link but some good insights:
https://www.capframex.com/blog/post/Abo ... g%20sector...
Bloods
Post by Bloods » 29 Sep 2022, 10:03
Specificity is king in this regard - Run the benchmarks with the EXACT same settings you would otherwise play with, that's the only way you are going to see if you are going to get real life improvements using ECO mode.
720p tests are fun to see for some general idea how the CPU performs with no bottlenecking in that specific game(engine) but only in a general sense.
Asus PG27AQDP(480HZ)
Acer Nitro XV252QF (390HZ) VRB Off, Overdrive: Normal) Max Brightness ON.
Asus VG248QE (144HZ)
Post by Chief Blur Buster » 29 Sep 2022, 19:58
daninthemix wrote:
29 Sep 2022, 01:01
Depends on what you're doing -- as a software developer, this is an important optimization tool.
Actually disabling Ultra and using 720p + low detail, in some engines amplifies CPU bottlenecks more than 720p + Ultra (usually, with most game engine workflows). Basically, the immutable minimum processing per frame (geometry updates, physics updates, hitboxes, controller updates, etc) generally scales with increased frame rates, so low-rez + low-detail will classically produce more CPU bottlenecks than low-rez + Ultra-detail, at least in classical game engine workflows.
While best practice recommends playing with real-world settings -- sometimes synthetic tests are necessary to reveal CPU weaknesses in the refresh rate race to retina refresh rates, especially when we're working with geometric-scaling problems. e.g. revealing weaknesses to optimize (optimizing software development, optimizing for VR rendering, etc).
High 720p+Ultra frame rates are useful for DLSS 3.0 type algorithms, so a software developer working on DLSS-less system may need to optimize CPU performance for 720p, which would help other members of the same software team that has DLSS.
It also makes porting the game codebase to Nintendo Switch, Steam Deck, mobile devices, and other 720p systems easier to do. The intentional method of amplify CPU problems by intentionally configuring the game settings to CPU-limiting settings and then optimizing the game source code to reduce CPU utilization.
This is also best concurrently done with artifically lowering of clockspeeds and core-count limiting, to amplify CPU bottlenecks more. -- to assist in coding optimization work.
