Razer Viper 8k Firmware update
evmadic
Re: Razer Viper 8k Firmware update
Post by evmadic » 15 Sep 2022, 12:27
Anyone know if there is a way to force the viper to poll at a constant 8khz?
For me the polling rate fluctuates between 4 and 8khz. I don't really notice it but a polling variance of 4,000 hz isn't really acceptable either.
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
masneb
Post by masneb » 14 Oct 2022, 05:20
Just want to add to this, I originally returned my mouse and got a new one after I did the firmware update. I also had the weird vibrating cursor issue completely unrelated to mouse surfaces or cleanliness. Since the firmware only fixed plugging issues that I never had a problem with it wasn't worth installing. Stock firmware worked best for me.
8000hz still has a bunch of weird, random, and completely unexpected bugs in games. I mean that in the purest sense. It really seems random what 8khz screws up. Makes no sense sometimes and I don't even think the developers have any idea what's going on. It might even be some sort of windows or USB standard issues. Still not fixed over a year later.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 21 Oct 2022, 22:14
mago
Post by mago » 29 Jan 2023, 14:15
https://mysupport.razer.com/app/answers ... rz01-03580
new fw
im seeing improvement
Razer Viper 8KHz Firmware Updater | RZ01-03580
Updated 04-Jan-2023 | Answer ID: 4540
Applicable Models
RZ01-03580
Firmware v1.03.01_r1
https://rzr.to/84LsT2 | January 4, 2023
Fixed an issue where the cursor will jitter/shutter when the mouse is set to high DPI.
β“ˆΠΊπ•€lŁ เ𝓒 α΅—β’ΊΠΌπ•‘Οƒο½’π€π‘β“Ž, lά𝔾 I𝐬 F𝔬ʳ𝔒𝓿ᗴ𝔯
masneb
Post by masneb » 07 Feb 2023, 00:50
mago wrote: ↑
29 Jan 2023, 14:15
new fw
Applicable Models
RZ01-03580
You can't downgrade your mouse to older firmware, I don't think I'm willing to risk firmware updates if I can't go back, even if I really want to try it. The last firmware update introduced that issue and it took them over a year to fix it. So I'd either have to buy a new mouse if it gets screwed or deal with support that will tell me I don't have a problem.
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 07 Feb 2023, 07:55
masneb
Post by masneb » 07 Feb 2023, 18:18
BTRY B 529th FA BN wrote: ↑
07 Feb 2023, 07:55
masneb wrote: ↑
07 Feb 2023, 00:50
mago wrote: ↑
29 Jan 2023, 14:15
new fw
Applicable Models
RZ01-03580
Actually you can. Find the older firmware you want. Run the install sequence. When it says you have the latest already, disconnect your mouse, hold Left Click + Scroll Click + Right Click button and reconnect. From there you should be able to run the old firmware updater. I just did this a few days ago with mine. The trouble is finding an older firmware install. I have all 3 of them.
This is very good to know as long as you aren't trolling with that comment, hope it doesn't get lost to the sands of time here as I've seen no procedure to go back, guess I didn't look deep enough.
mago
Post by mago » 07 Feb 2023, 18:22
https://www.youtube.com/watch?v=jEnxcAtDqCw
How to downgrade A Razer Viper 8khz (or some other Razer models) firmware
BTRY B 529th FA BN
Post by BTRY B 529th FA BN » 07 Feb 2023, 18:27
mago
Post by mago » 23 Apr 2023, 13:41
Code: Select all
; Made by Reknotic
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\mouclass\Parameters]
"MouseDataQueueSize"=dword:0000000a
looking to be helpful with razor 8k and csgo mouse stuttering
headshots
