Ever since I build this PC problems started and my performance in game was noticeably worse. At the time I was questioning everything but the PC. Thinking that my issues are electricity related or from my ISP or even EMI.
My build is from avril 2017
i7 7700k
MSI Z270 Gaming Pro Carbon
16 GB 3000Mhz CL15
GTX 1080
1TB SSD
I literally spend thousands and thousands of Euros; I changed my power supply, tried every ISP in my country, changed high end routers several times, bought a UPS. Hell I even moved from 2 different house in 6 years... The problem persisted no matter what.
My problems are exactly what most of you guys describe on these topics. Heavy cursor feeling, i get pre-fired most of the time or bullets do not register, i die before even seeing enemies, like if they see me 1sec or 0,5sec before i even see them, etc...
I mainly play competitive FPS (CSGO, Valorant, etc) I have more than 9000Hours on Steam only on CSGO and a bit more than 1000h on Valorant.
I bought more than 10 different mice, a few different mousepads and 4, 5 different keyboards. Tried a bunch of 240Hz monitors... still the problems persisted.
Tried every single thing you can think of. Tweaked windows, very low dpc latency optimization, clean install with older version of windows, older nvidia drivers, etc. Took my PC at my friends house, etc. Nothing worked.
Then my professional life changed and I got less time to play for almost 2 years, so I forgot a bit about it; until a few months ago. So, because I have more free time now; I decided to try again the games I used to dominate on (CSGO &Valorant mostly).
and no surprise... My nightmares started again as described above.
Then by chance i found the reason for all this input lag that i have been experiencing since 6 years... and it is the dumbest thing ever...
I unplugged my ethernet cable and instantly my DPI felt like it doubled. Very curious about why i connected my Android phone (used LTE USB tethering) and played on some servers i always used to play on. My mouse sensor was snappy like i have never felt before, the PC was way more responsive (even the strafing on the keyboard) It was mind boggling, i just could not believe it. It was like I was playing another game. Bullet would register correctly and enemies were dying faster on a jittery 4G LTE connection with 60ms ping than a 1GB/s Fiber connection with very minimal jitter and 9ping....
So I suspected the network chipset on my MSI Z270 motherboard ( Intel I219-V )
What I did to confirm my theory is that I went to my office and took an old PC that we are not using anymore which got a i5 4460, gtx 750Ti and 8Gb of ram. But most importantly... a Realtek network chipset
Did a clean Windows 10 install with latest drivers and installed CSGO and Valorant even though this PC was way slower than my personal PC (max 150fps with lowest settings / on my PC i have way above 300Fps stable)
There was no issue, this slower OEM PC with Realtek network chip felt way more responsive and my mouse was snappier. I never felt like i got pre fired or even died before seeing the enemy. Plus it had a correct bullet registration which was not the case at all with my PC with the Intel Network Chipset.
Yeah you read that right, i spend THOUSANDS and THOUSANDS of Euros, tried every ISP, played 6 years with a very noticeable input lag all of that because of a trash Intel Network Chip. There is literally no fix, it is the exact same since I bought all the parts in 2017 with every drivers updates, every windows version and builds since then, every single tweak you can think of, there is no solution; if I connect my Ethernet Cable my DPI are divided by 2 and I have an insane input lag and noticeable disadvantage in game. Everything disappear when I use USB tethering and unplug the ethernet cable.
Which is totally not the case on an older and slower OEM PC with a realtek network chipset. I would have never ever imagined that a network chipset on a motherboard could make such a difference.
Plugging / unplugging the ethernet cable on the motherboard with Intel Network Chipset ( Intel I219-V ) made a very noticeable difference in gameplay feeling and cursor speed while on the motherboard with Realtek Network Chipset there was 0 difference if the exact same ethernet cable is plugged / unplugged.
Curious to know if any of you got a similar experience or know more about that subject?
UPDATE:
Apparent fascinating data about apparent latency savings (3ms claimed) by bypassing onboard and using USB-C or PCIe Ethernet. Read More Here
