What transformer model are you using?
This fixes the electrical input lag
- F1zus
Re: This fixes the electrical input lag
First, it hasn't been tested yet.Skeezv wrote: ↑12 Dec 2022, 12:03This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
https://aliexpress.ru/item/400034986321 ... b7340abb90
Secondly, you did not personally try it, but read all sorts of nonsense and threw a link here.
Do you want people to waste money?
First you need to check it yourself, and then post links.
itsjNs
Hey I thought you fixed the input lag by going OFF GRID can you tell me your experience with solar panel system?
Did you fix it and just trying to figure out what causing the issues on grid? or you never fixed it completly?
Transformers don't get "infected". Something perhaps may happens after a while (e.g. cyclic interference, damage, etc), but it's not the word "infected".
texre
Going off grid completely fixes it. Unless you charge the battery with your electricity. Then you have to wait for all bad energy to leave. I want a fix on grid so I can play longer and it’s also winter time rn so the sun isn’t charging the batteries fast enough for me.
Sqnax17
the transformer mentioned, does it work or not? where is the evidence? evidence?Skeezv wrote: ↑12 Dec 2022, 12:03This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
MegaMelmek
Work like what? Like fixing input lag - what is input lag? show me evidence of input lag? I need evidence…Sqnax17 wrote: ↑14 Dec 2022, 11:47the transformer mentioned, does it work or not? where is the evidence? evidence?Skeezv wrote: ↑12 Dec 2022, 12:03This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
Sqnax17
well... if they're saying it fixes the input lag caused by bad electricity, show us the truth.MegaMelmek wrote: ↑14 Dec 2022, 12:52Work like what? Like fixing input lag - what is input lag? show me evidence of input lag? I need evidence…Sqnax17 wrote: ↑14 Dec 2022, 11:47the transformer mentioned, does it work or not? where is the evidence? evidence?Skeezv wrote: ↑12 Dec 2022, 12:03This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
- F1zus
There is no proof and never will be. He just read a message from 1 person who bought this transformer and created a topic here. But as it turned out later, the input lag still sometimes appears even with a transformer. Therefore, I advise you not to throw away money.Sqnax17 wrote: ↑14 Dec 2022, 11:47the transformer mentioned, does it work or not? where is the evidence? evidence?Skeezv wrote: ↑12 Dec 2022, 12:03This thing fixes the input lag, a few people have already helped in the Russlan group where there are 300+ people. Toroidal balanced isolation transformer
- dervu
There is something that toroidal transformers don't like, DC component. If you can hear it buzzing, then it means there is some DC. Then performance drops. I do not know if performance drop is high enough to cause any issues, maybe if someone bought low VA and is borderline enough?
Another thing worth considering is if nothing is going through ground cable, since it is the only cable having direct connection in balanced toroidal transformer. Myself I decided to work with ungrounded, if it fails at least I will know whatever was causing it, went through live or neutral that completely goes through transformer.
