just wanted to add my 2 cents:
i'm using an xl2731k, the instructions did not yield me any results. i am able to create a custom resolution up to 174hz in Nvidia Control Panel without mcss or any other programs, but using it for 175hz and up, i am unable to do any more than dismiss the Out Of Range pop-up.
BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
That's so easy to fix with another HDMI cable connected to the same or to another graphics card and to the same monitor,
you can open Benq Software Application Display Pilot and change Color profile, then with another DDC / CI command controller software called ControlMyMonitor you search for the HDMI display and put the OSD Language into the same Number that is the Current Value,
then just press enter and Out of Range message will dissapear, you should use two monitors, I've been able to do it in my case just in one but its a bit tedious and you must revert it before restarting the system so you wont get black screen down.
So the procedure will be with CLUB 3D 1010 Display port to DVI adapter:
1. Connect another cable to HDMI graphics card to the BENQ screen.
2. Download specific display pilot driver workable with your actual monitor.
3. Change resolution to your desired overclocked input.
4. Go to color settings in Display Pilot and change it to any other profile to get rid back from the Out of Range Message
5. Save the setting if you have Input Signal.
6. Go to ControlMyMonitor and search for OSD Language, if that doesnt appear yet, or the Color option from Display Pilot,
you just Close the application or finish it with CTRL+Alt+Supr and open it again, if your HDMI cable is able to do DDC / CI commands,
you will always be able to do all of this. ControlMyMonitor OSD Language put the same value and press enter until Out of Range dissapears
7. Enjoy and be always aware of the same Overclock procedures from the softmccs or oorbuster trick.
Mine is XL2411Z firmware V004 and I always do this when I start my windows to enjoy 179Hz, feels just right better than 144Hz,
even I cant go further with it, cheers and good luck!!
Hello mate, thanks for your answer. By the way, i didnt understand how to really do it.. i have to put the custom resolution when im on the HDMI INPUT in the same monitor? i sincerely didnt understand pretty much nothing, i downloaded the 2 softwares but the BENQ one didnt show the color panel.. probably i have an old monitor.. i have xl2411 normalThaSome wrote: ↑29 Dec 2022, 09:03That's so easy to fix with another HDMI cable connected to the same or to another graphics card and to the same monitor,
Unfortunately, like BENQ site says, XL2411P doesnt support Display Pilot.. So i only can rotate the screen at 90, 180, 270.
SO BAD.....
SO BAD.....
Hello i have benq zowie xl2411z i wouldl like to overclock but when i try to create custom resolution with amd graphic card or cru it tells me that i cant create cause display doesn't support this resolution (this monitor is only via DVI).
Any help?
Any help?
You have to patch AMD driver. Sometimes it happens with radeon software, but on cru you have to set the timings of resolution properly and then make the Restart.64 exe
I have xl2430 with S-Switch and latest firmware and I can't get past Out of range promt. Pressing S-Switch 1-3 buttons doesn't do anything, oorbuster and oorfixer also don't work. Am I screwed?
I have the xl2411p that managed to hit 220 hz with CRU so I'm curious about the ms response time so I need to know which is faster (144hz with ama: premium / blur reduction: off or 220 hz with ama: off / blur reduction: on)
