Hi guys, i messed up with my factory menu settings and i want to see the default values, because factory reset doesn't work at all.
How can you get into factory menu: hold the top button (joystick) when you are starting the monitor, then open OSD menu and you will see "F" at the top left, which is the factory menu, open it and show me default values please.
It might look like this:
Asus ROG XG258Q owners please help
Boomchakadah
Re: Asus ROG XG258Q owners please help
which setting do you think you messed up?
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Re: @Boomchakadah
SSC Frequency, SSC Permillage, and sRGB settings
Find attached my factory settings. Thanks for the info on the F. You learn something new each day.
Damn it. I wish I'd have known that the settings stick even after a factory reset from within that menu. I just learned about this F menu and accidentally altered random RGB values (quite easy to do if it's your first time navigating.), but assumed they'd reset, so I wasn't fussed at the time. A lot of mine are different. Pretty sure I didn't accidentally change so many...
You said you needed sRGB values, yet most of your other stuff doesn't match up either. Does each monitor have different factory values?
I ended up having to copy those provided as I have absolutely no idea which I accidentally changed.
Mine is a 20170730 MCM101 though. Whatever that is.
Edit: Does it even work? I set the brightness of sRBG to 100 in the F menu as a test. When I switch to GameVisual>SRGB Mode the brightness is of course greyed out, but is shown at 19.
Edit: It does I guess. Just not brightness? I reduced red all the way down and that sticks in GameVisual>SRGB Mode.
Grrr so annoyed with myself. I swear the colours don't look right now.
For the hell of it I've attached my settings I potentially screwed up
- IMG_20230507_173458.jpg (4.59 MiB) Viewed 3001 times
