Speculation that an EHCI-Controller (USB 2.0) performs better than xHCI with mice
Re: Speculation that an EHCI-Controller (USB 2.0) performs better than xHCI with mice
Post by Slender » 19 Jan 2023, 02:52
RealNC wrote:
19 Jan 2023, 02:48
Slender wrote:
16 Jan 2023, 22:28
RealNC wrote:
14 Jan 2023, 22:07
Are you on a Ryzen CPU? Apparently the USB ports that are connected to the CPU instead of the chipset can cause issues with input devices.
what?
Google "ryzen usb bug". Here's a reddit thread about it. During high CPU load, the CPU-connected USB ports can become unreliable.
same on chipset (delta in mousetester 990-1010 (but stable))
on cpu usb, if im off graphic driver my line is like on intel setup.
viewtopic.php?f=10&t=10511&p=86303#p86303
also im try to use usb 2.0/usb 3.0 pci-e controllers but nothing.
Mousetester in chipset usb (5800xb2).jpg (218.92 KiB) Viewed 1902 times
Post by Slender » 19 Jan 2023, 03:14
ryzen cpu usb
setting - cpu idle (on/off)
