Hello everyone.
First of all, sorry for my English. I am Spanish and I am using a translator.
Some time ago I saw the LG OLED C1 TV at a friend's house. I had been told it was the best TV around for clarity of motion. I saw a PS5 game at 60hz and I didn't like it at all. It had a lot of blurring. I then watched the same game at 120hz, and the image improved, but still had a significant amount of blurring.
Then I came to think that there was no OLED TV that could have motion clarity like a CRT (I'm a fan of motion clarity and CRTs). I am a console player. I currently play on a Benq XL2411P and a Viewsonic XG2431. At the moment they are the only two monitors that have given me the clarity of movement at 60hz comparable to a CRT. Of course accompanied by the essential Blur Buster Strobe Utility
On February 22 I bought the PSVR2. This viewer has a mode in which it simulates being in front of a large oled-type cinema screen at 120 hz.
Well, I saw a game at 120hz in the viewfinder and it was PERFECT!!!! It looked exactly like a CRT. The clarity of movement was PERFECT and the response of the controls was also perfect (no input lag at all).
My question is: Is there any OLED television or monitor that provides me with that image clarity at 120 Hz. So perfect?
I was researching and I read something about current oled televisions having a persistence of 4ms, but these types of viewers had a persistence of 2ms.
I don't know if what I'm saying is correct.
Long story short, I'm looking for an oled tv or monitor that achieves absolute perfection in image clarity at 120hz, just like the PSVR 2 in cinematic mode.
And, of course, without input lag. The fascinating thing about the viewfinder is that it achieves that clarity of movement only by activating 120hz. No need for BFI or anything that affects input lag.
Thank you very much for reading me.
All the best
PSVR 2 Cinematic Mode. Best Motion Clarity EVER
Angel Soler
- jorimt
Re: PSVR 2 Cinematic Mode. Best Motion Clarity EVER
The PSVR2 has strobing OLED displays.Angel Soler wrote: ↑11 Mar 2023, 03:26The fascinating thing about the viewfinder is that it achieves that clarity of movement only by activating 120hz. No need for BFI or anything that affects input lag.
Virtually all VR headsets (LCD and OLED) strobe, whereas most of the latest OLED-type TV and monitor models currently don't.
Angel Soler
Now I understand why it looks so smooth hahahaha.jorimt wrote: ↑11 Mar 2023, 11:00The PSVR2 has strobing OLED displays.Angel Soler wrote: ↑11 Mar 2023, 03:26The fascinating thing about the viewfinder is that it achieves that clarity of movement only by activating 120hz. No need for BFI or anything that affects input lag.
I didn't know it was in strobe mode.
Thank you very much for answering me
Well, the key will be to find an OLED television that has strobe mode at 120 hz
You can get an LG C9 to reduce 120Hz motion blur by 50%, but not like a CRT.Angel Soler wrote: ↑11 Mar 2023, 11:31Well, the key will be to find an OLED television that has strobe mode at 120 hz
PSVR2 uses a custom OLED capable of strobing much briefer than the world's best OLED TV.
It's all about BFI Pulse width.
Angel Soler
ok, now i understand everythingChief Blur Buster wrote: ↑12 Mar 2023, 03:36You can get an LG C9 to reduce 120Hz motion blur by 50%, but not like a CRT.Angel Soler wrote: ↑11 Mar 2023, 11:31Well, the key will be to find an OLED television that has strobe mode at 120 hz
Thank you very much for answering and helping me.
Well, we will continue waiting for the TV or Oled monitor to achieve the perfection of a CRT.
Surely some oled monitor with Blur Buster certification ends up coming out. I will buy it without thinking.
Meanwhile, content with Xl 2411P and XG2431
Thank you very much again and regards
Ángel
- NeonPizza
So Quest 2 has a sub 1ms motion persistence @100nits.
Does that also apply to the Quest 3 as well?
PSVR2 at it's best, motion wise, does 2ms at only 60nits with the VR brightness slider dropped to zero. Once you get to the 4th or 5th slider notch I've been told you're at around 110nits, but then the persistence becomes slower and head movement blur becomes obvious. it's like you're trading motion for brightness, and it's up to the user to find that happy medium. Ideally, sub 1ms over 120nits would be great if possible.
Wonder where the Apple Vision Pro ranks with it's micro-oled display.
