No matter what you change in the BIOS, everything will come back after a while. Let them cope a little bit with their superior bios settingsNOH wrote: ↑01 Apr 2023, 10:59Can you tell some specific settings youve changed that you suspect gave the most impact ?Mugabi wrote: ↑31 Mar 2023, 19:06Update yes indeed, after tweaking more n more, my system became lightning fast , I melt ppl with headshots left n right, it’s super weird how bullets work now, the moment you shoot u see them piercing through ppl and walls opposite of the map which is crazy n nuts. Now there is something missing that I haven’t mentioned, the system became unstable and screen was shaking many times, this was bareable for me. Also like I said earlier, the main layer of lag which could be internet /server is still there, ie my whole game character feels abit behind in the server even tho my bullets are really fast at landing. Also, one of the settings I changed made sound don’t work, now I have to find which one. I feel in windows 10 this woulnt happen I’m using 11 now.
it is actually distorted signal on motherboard (internal emi )
Re: it is actually distorted signal on motherboard (internal emi )
I will post both my default and my optimised bios files and y’all see cuz there are simply too many things changed by me. Be careful that my changed values might be specific to my mobo/cpu and operating system
Have you done this already ?n1zoo wrote: ↑01 Apr 2023, 13:05No matter what you change in the BIOS, everything will come back after a while. Let them cope a little bit with their superior bios settingsNOH wrote: ↑01 Apr 2023, 10:59Can you tell some specific settings youve changed that you suspect gave the most impact ?Mugabi wrote: ↑31 Mar 2023, 19:06Update yes indeed, after tweaking more n more, my system became lightning fast , I melt ppl with headshots left n right, it’s super weird how bullets work now, the moment you shoot u see them piercing through ppl and walls opposite of the map which is crazy n nuts. Now there is something missing that I haven’t mentioned, the system became unstable and screen was shaking many times, this was bareable for me. Also like I said earlier, the main layer of lag which could be internet /server is still there, ie my whole game character feels abit behind in the server even tho my bullets are really fast at landing. Also, one of the settings I changed made sound don’t work, now I have to find which one. I feel in windows 10 this woulnt happen I’m using 11 now.
Ppl who claim this don’t have affect didn’t try it themeselves cuz they lazy
lets see how long it will last. Also is chat gpt able to explain all the settings in detail?
When discussing GPT, always ask what version of ChatGPT.
There's many models/personalities of GPT.
Some GPT's are 10x better than other GPT's.
Just because one GPT gives crap answers, doesn't mean a different GPT model will.
The paid GPT-4 ($20/month at chat.openai.com) is vastly superior to the free GPT 3.5 in many skills. And always verify, even in "trust-but-verify" situations. Don't blindly follow tweaks that GPT suggests, always cross-reference with multiple sources.
Also, the OpenAI version of GPT4 is better than the Bing Chat version of GPT4, because it's configured to give more detailed/verbose explanations, more useful context, and you have unlimited-length conversations (rather than just 15 back-and-fourth turns). Some answers can be good while other answers are terrible (GPT 4 is far better than the GPT 3.5 when it comes to answers for tweaking).
After couple of days, the change is consistent but i have noticed, it works pretty well when you go back and forth between the default and changed settings. If you play longer with the changed settings, it becomes abit laggy but nothing too major. I would give this a solid rating of 6/10 compared to a fresh windows reinstall that i used to do before when it comes to have effective it is and how long it lasts . Also, i changed million settings by now but there some settings op mentioned but i didnt find or didnt change which are according to him clock impedance (which clock impedance?) , pcie lanes impedance (which pcie lanes impedance?) and sata impedance , couldnt find those and we have the same mobo/bios
I would like to know op and texre experience with it so far tho.
loccomacco
Thank you for giving more infos, I knew it won't fix the whole thing, because there are people in this forum including myself, who already tweaked their bios by guides across internet and discord servers, they do something, but at the end, you still face some specific times during days and nights when there are no issues and it's like you're in heaven, no washed out or blurry screen, fps is high as it should be, mouse works a lot snappier, no more input lag or latency, best aim and hitregs.Mugabi wrote: ↑03 Apr 2023, 19:51After couple of days, the change is consistent but i have noticed, it works pretty well when you go back and forth between the default and changed settings. If you play longer with the changed settings, it becomes abit laggy but nothing too major. I would give this a solid rating of 6/10 compared to a fresh windows reinstall that i used to do before when it comes to have effective it is and how long it lasts . Also, i changed million settings by now but there some settings op mentioned but i didnt find or didnt change which are according to him clock impedance (which clock impedance?) , pcie lanes impedance (which pcie lanes impedance?) and sata impedance , couldnt find those and we have the same mobo/bios
