(INTEL ONLY) An easy way to instantly lower input latency
atmk44
Post by atmk44 » 31 Mar 2023, 04:10
What is usb interrupt coalescing and how to disable it
Apparently doesn't work on win 11
Recently found this youtube channel, the guy posts a lot of interesting videos telling and showing you about stuff that you won't get spoonfed, which is literally free information so you don't want to miss out
Credit: RealJerryXOC#7693
deama
Re: (INTEL ONLY) An easy way to instantly lower input latency
Post by deama » 01 Apr 2023, 03:15
I wonder how to do this for amd?
SKILLEN
Post by SKILLEN » 01 Apr 2023, 11:29
Error - Driver cannot be loaded,re-installing the program may fix the issue.
intel 12400f
B660m asus prime D4
Tiberiusmoon
Post by Tiberiusmoon » 01 Apr 2023, 15:33
After looking around at various settings to reduce latency, at the end of the day I just stick to users who have external latency tests to backup their claims otherwise you don't know how much latency is reduced.
Mr1991
Post by Mr1991 » 01 Apr 2023, 18:08
Sucks that you have to apply it every boot, wonder if there’s a way to make it permanent
timecard
Post by timecard » 01 Apr 2023, 22:34
This is interrupt moderation for Intel USB xhci controllers, Windows 8 and 10 both use 50 microsecond (us) interrupt moderation rate by default. It might help if you have mouse with more than 1000hz polling rate otherwise won't do much.
skkiNN
Post by skkiNN » 02 Apr 2023, 09:36
SKILLEN wrote:
01 Apr 2023, 11:29
intel 12400f
B660m asus prime D4
Same here..
i7 7700k
z270
Unreazz
Post by Unreazz » 03 Apr 2023, 06:03
That is Eonds YT Channel
Mr1991
Post by Mr1991 » 04 Apr 2023, 15:12
timecard wrote:
01 Apr 2023, 22:34
So what benefit does it have by disabling, if it’s already 50 mcs by default, which is already low?
timecard
Post by timecard » 06 Apr 2023, 23:56
Mr1991 wrote:
04 Apr 2023, 15:12
timecard wrote:
01 Apr 2023, 22:34
That's what I'm saying, it doesn't unless you have 8000hz mouse.
