24G2U Distortion at "Moving Photo" test , videos, vsynced/fps capped games
amorou
Post by amorou » 11 Apr 2023, 16:25
It starts immediately after Chrome's fullscreen notification disappears , before that , with the black/grey pop-up , issue not present on "moving photo test"
** Last part in video ( 0.13 sec mark ) i track it with camera its much more visible
Its like old winamp eq animations
Distortion lies all the way horizontaly without break-up.
Edit:Video added.
Chief Blur Buster wrote:
16 Apr 2023, 19:12
Solution:
Reset your NVIDIA Control Panel settings and make sure you're not using VSYNC OFF for fullscreen mode.
Ideally, you should only set VSYNC OFF on a per-application basis, and never for global fullscreen usage.
Manage 3D Settings -> Global Settings -> Vertical Sync -> Use the 3D application setting
For TestUFO, you don't want web browsers such as Google Chrome to use VSYNC OFF in fullscreen mode.
If you want to force VSYNC OFF, do it via in-game and/or the Program Settings.
WhatsApp Image 2023-04-15 at 03.20.48.jpeg (110 KiB) Viewed 9606 times
WhatsApp Video 2023-04-14 at 23.52.30.mp4
(4.81 MiB) Downloaded 433 times
amorou
Re: 24G2U Distortion at "Moving Photo" test , videos, vsynced/fps capped games
Post by amorou » 13 Apr 2023, 10:52
Anyone?
Boomchakadah
Post by Boomchakadah » 14 Apr 2023, 02:26
Can you post a video?
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
amorou
Post by amorou » 14 Apr 2023, 15:59
Boomchakadah wrote:
14 Apr 2023, 02:26
Video added and
Boomchakadah
Post by Boomchakadah » 14 Apr 2023, 19:04
amorou wrote:
14 Apr 2023, 15:59
Boomchakadah wrote:
14 Apr 2023, 02:26
Video added and
That looks like screentearing.
Does it happen at lower refresh rates like 60hz as well? does it happen in microsoft edge?
Make sure hardware acceleration is enabled in Chrome settings. Make sure Freesync is enabled. If you have an Nvidia GPU, make sure G-SYNC for full screen is enabled.
Run a frame-skipping test to make sure your monitor isn't skipping frames. https://youtu.be/3xiPSkQSX5A?t=194
amorou
Post by amorou » 14 Apr 2023, 19:15
Boomchakadah wrote:
14 Apr 2023, 19:04
amorou wrote:
14 Apr 2023, 15:59
Boomchakadah wrote:
14 Apr 2023, 02:26
Video added and
It happens on 60 / 75 / 120 / 144 hz
Issue persists on edge , on chrome Hardware accel enabled.
Freesync disabled on osd by me , I have nvidia gpu , personally I dont like it .
Do u want me to enabled it for testing purposes or ?
Also tried all settings on osd (manually selecting input method, colour stuff , overdrive , black level vs)
Tried lots of diffrent timings with cru
I tought I checked for frameskipping , but I didnt capture the pic while moving squares were on top ( where problem exist) so I did that here it is
It only happens on 2nd column
WhatsApp Image 2023-04-15 at 03.20.48.jpeg (110 KiB) Viewed 9607 times
amorou
Post by amorou » 14 Apr 2023, 19:34
amorou wrote:
14 Apr 2023, 19:15
Boomchakadah wrote:
14 Apr 2023, 19:04
amorou wrote:
14 Apr 2023, 15:59
Boomchakadah wrote:
14 Apr 2023, 02:26
Video added and
Boomchakadah
Post by Boomchakadah » 14 Apr 2023, 19:34
amorou wrote:
14 Apr 2023, 19:15
Yes.
Boomchakadah
Post by Boomchakadah » 15 Apr 2023, 04:11
amorou wrote:
14 Apr 2023, 19:15
Yes.
If enabling Freesync/G-sync doesn't fix it, there is something wrong with that monitor. Return it or contact AOC for a replacement.
amorou
Post by amorou » 15 Apr 2023, 06:33
Ty
