Angel Soler
Post by Angel Soler » 18 Apr 2023, 07:16
Let's see, I need to know which monitor has more clarity at 240 hz in strobe mode.
The XG2431 or the XL2566k.
Since, if I'm not mistaken, the XL2566k, being a 360hz panel, should have a better strobe mode at 240hz.
Thank you so much
xkashimx
Post by xkashimx » 18 Apr 2023, 07:59
hi guys,i actually owned odyssey g7 32",i like it bought i m not satisfied 100%,i play 95% of time competitive games,when i bought my g7 i was looking for something competitive,with low response time and input lag but without sacrifice picture quality...wanna know if i sell my g7 and buy this monitor if is worth it and if this monitor is better for my prupose(competitive gaming but not tn like xl2566k)
xkashimx
Post by xkashimx » 18 Apr 2023, 08:02
Angel Soler wrote: ↑
18 Apr 2023, 07:16
Thank you so much
if i m right xl2566k have a little better mbr,have better brightness(can be adjusted with dyac on),but is tn,simply faster and more esport focused but sacrifice picture quality and colours
masterblaster
Post by masterblaster » 18 Apr 2023, 08:09
18 Apr 2023, 07:16
Thank you so much
And also costs $600 vs $280....
xkashimx
Post by xkashimx » 18 Apr 2023, 10:06
then,cost more for little more clear image but sacrifice all colours and money,maybe not worth it...upgrade only if u are competitive focued only and wan t the best and fastest monitor for competitive
masterblaster wrote: ↑
18 Apr 2023, 08:09
18 Apr 2023, 07:16
Thank you so much
master u think is worth it sell my g7 for this xg2431?i m with 32",ppi 1440p 32" and 1080p 24" are the same
masterblaster
Post by masterblaster » 18 Apr 2023, 10:59
xkashimx wrote: ↑
18 Apr 2023, 10:06
18 Apr 2023, 08:09
18 Apr 2023, 07:16
Thank you so much
I dont know. You dont like the g7 or something? I am not into 32" monitors for gaming so... My pick would be the xg2431. I would pick the xl2566k if it were in the $350 price range for sure, but benq has crazy pricing for their monitors. $600 is way to much for a tn panel. Theres nothing special about the monitor except for dyac so, youre literally paying $300 extra for one "feature".
xkashimx
Post by xkashimx » 18 Apr 2023, 13:03
18 Apr 2023, 10:59
xkashimx wrote: ↑
18 Apr 2023, 10:06
18 Apr 2023, 08:09
18 Apr 2023, 07:16
Thank you so much
yes 32" too big for 1440p and competitive gaming...make resolution difference soo tiny...then for you if i grab xg2431 is worth it?i have found 2nd hand xl2566k for 450 euro and xg2431 new for 350...but i m scared to tn panel,sacrifice too muchj quality only for dyac,maybe xg2431 is not as clearer and brighter but have better colours,and i can use it without purexp whenm not needed for extrra brightness,right?
masterblaster
Post by masterblaster » 18 Apr 2023, 13:59
xkashimx wrote: ↑
18 Apr 2023, 13:03
18 Apr 2023, 10:59
xkashimx wrote: ↑
18 Apr 2023, 10:06
18 Apr 2023, 08:09
Well if the xl2566k is only a small price difference then I might pick that. I dont know. TN panels suck for anything besides gaming because of colors and viewing angles.
One good thing for xg2431 is because its 23.8, its higher image quality for 1080p because its smaller. So that makes it a little more "crisp". Generally speaking, anything higher refresh rate is going to be better in terms of raw performance so on paper the xl2566k is better. You just have to be fine paying a higher price for low quality colors and viewing angels.
Durgers
Post by Durgers » 18 Apr 2023, 14:16
Qooqan wrote: ↑
18 Apr 2023, 06:56
Durgers wrote: ↑
17 Apr 2023, 23:18
Received my XG2431, gotta say its amazing so far in terms of clarity and responsiveness. But I noticed this odd line on the top of the screen on both sides. It does not bother me as it's in the borders of the actual screen. But I am just curious if this is a QC problem or if anyone else has this too.
i dont have this line, you should return ur monitor
I don't think I will return it just for this, as I feel like I've got pretty lucky with the ips glow but it's just super odd, It's not as noticeable in person compared to the photo since that's quite a close-up of the actual lines. Good to know it's just me tho.
Angel Soler
Post by Angel Soler » 19 Apr 2023, 00:13
xkashimx wrote: ↑
18 Apr 2023, 08:02
18 Apr 2023, 07:16
Thank you so much
Thank you for respond me ☺️💪
