How to fix it?
simple for 13700k
use bcdedit /set numproc 8 (if you dont use HT) 16 (if you use HT)
Enable all e-cores in bios
Disable e-cores in bios cause high DPC/ISR usb controller
- Slender
- all e-cores disable in bios1.png (40 KiB) Viewed 6213 times
- all e-cores disable in bios.PNG (13.75 KiB) Viewed 6213 times
- Slender
Re: Disable e-cores in bios cause high DPC/ISR usb controller
Enable in bios / disable in OS
- all e-cores enable in bios disable in os1.PNG (13.16 KiB) Viewed 6211 times
- all e-cores enable in bios disable in os .png (37.61 KiB) Viewed 6211 times
ptuga
Why would you even want to disable e cores in 13th gen?? From my testing with 13700kf it's best to leave them on.
With 13th gen you can actually do e cores on + HT off and with the headroom drop voltage or increase clocks. E cores off waste of time, slower and doesn't allow more OC at all.
- Slender
yes, if you on win11, but if you want more responsive system, you go with win10.ptuga wrote: ↑16 Apr 2023, 14:39Why would you even want to disable e cores in 13th gen?? From my testing with 13700kf it's best to leave them on.
And win10 works bad with e-cores, games consider e-cores=p-cores and transfers its threads to these cores, and we know that these cores have a terrible inter-core delay, which causes stuttering. Everything is more complicated than you think.
masneb
I assume this was tested with c-states off?
- Slender
