I just got a new monitor, a 360Hz Asus PG27AQN. I also own a 240Hz Asus PG279QM and a 165Hz Asus PG279Q.
No matter what I do or try, the UFO test will show the message:
"SYNC FAILURE: Unable to VSYNC. Try closing all apps and browser tabs."
Or after a few moments, if I am lucky, it will switch to:
"PERFORMANCE WARNING: Potential browser stutter occured (1)" or
"STUTTER WARNING: Browser stutter detected (1+). Close other apps and tabs." and it will go up by several numbers.
- I have unplugged the other monitors to test individually each
- used Firefox, Chrome and Edge, closed everything in system tray
- uninstalled every control program I had, rgb or not (including Asus, NZXT, G.Skill, Razer, iCue, Lian Li, Base Camp)
- reinstalled GPU drivers from scratch
- resized window
- changed settings in Nvidia control panel, reset them back to default too
- tested both 360 and 240 Hz and 2 different monitors
- even unplugged USBs I thought may have something to do with it
This is just to name a few. I am running a 13900k and a 4090 so I do have the components to run this smoothly.
It will say ready a lot more often on the 165Hz but anything above it struggles to even show ready at all. Even when it does show ready though, I get the stutter warning every 3-5 seconds basically. Don't know what else to do. Here are the animation timings as well:
Errors no matter what I try
Re: Errors no matter what I try
wot do you have for drivers in autoruns64?
here's mine:
here's mine:
Here are my drivers:
I noticed FireFox sometimes has more problems than Chrome in running TestUFO on 360Hz monitors.
Can you screenshot this graph using Edge or Chrome or Opera (any chromium-engined browser).
Still looking for help on this if anyone knows anything
Different-Hz multimonitor creates gigantic problems with latency/stutter for windowed and borderless windowed.
1. Test single-monitor mode. Is it smooth?
2. Next, try playing your games in fullscreen exclusive mode.
Never use windowed/borderless with multimonitor if you care about lag!
Microsoft Windows is a single-Hz compositor, which means activity on all monitors will jitter/stutter each other. If you use TestUFO, make sure you use it on the primary monitor, and make sure nothing is happening on the secondary monitors. But that can be hard to do if you're using the 2nd monitor for things like Discord or Twitch or other stuff.
If you use multimonitor in esports, make sure you're using fullscreen exclusive, and if you must display stuff on other monitors at the same time as a competitive game -- make sure you run software such as Project Lasso (or other CPU-limiters) on your secondary software to prevent the software from grabbing too much CPU time (e.g. limit Discord to 10% or less of CPU).
_____
FYI.... Have you considered replacing with fewer monitors?
I have many monitors here, but I have chosen to outfit my desk with a 45" Corsair Xeneon Flex 240Hz OLED. It's quite neat and a practical multimonitor substitute, having the surface area of approximately two esports monitors, while concurrently being clearer motion than 360Hz nonstrobed.
(The wallpaper is not always displayed, but it makes a good photoshoot background!)
