Best Config for Valorant
sherifmagdy32
Post by sherifmagdy32 » 25 May 2023, 21:44
Since a lot of people having problems with VALORANT
i wanted to share this config with you
this will mostly help people with mid to low tier PC or on laptops
most of these values works for any Unreal Engine game
make sure to make a backup in case you didnot like the settings for some reason
config file location "C:\Users\UserName\AppData\Local\VALORANT\Saved\Config\"
sort by date modified open the latest one then open Windows folder if you cannot find it go to the next folder in order till you find it
you should find the config file inside the Windows folder
config
https://drive.google.com/file/d/1xOGBkE ... sp=sharing
virustotal scan
https://www.virustotal.com/gui/url/47eb ... ?nocache=1
when it comes to hitreg issue i recommend trying warp
with this setting as this has the lowest impact when it comes to latency
this should fix most routing and bypass most ISP's throttling
(Preference -> connection -> DNS protocol -> HTTPS)
only use warp if you feel l like having bad routing or being throttled by your ISP
because other than this it might actually increase your ping or even hurt your connection more than it will help
https://1.1.1.1/
Sebichek45
Re: Best Config for Valorant
Post by Sebichek45 » 26 May 2023, 05:00
sherifmagdy32 wrote: ↑
25 May 2023, 21:44
https://1.1.1.1/
use this to get free GB
https://github.com/TheCaduceus/WARP-UNLIMITED-ADVANCED
config
virustotal scan
Can this be used with your power plan?
sherifmagdy32
Post by sherifmagdy32 » 26 May 2023, 10:47
Sebichek45 wrote: ↑
26 May 2023, 05:00
25 May 2023, 21:44
https://1.1.1.1/
config
virustotal scan
Yes you can use this config no matter what power plan you are on let me know how the game feels after you use it
bumbeen
Post by bumbeen » 26 May 2023, 12:57
Correct me if I’m wrong here, I thought only Warp+ actually pipes more than only DNS traffic through Cloudflare?
sherifmagdy32
Post by sherifmagdy32 » 26 May 2023, 19:03
bumbeen wrote: ↑
26 May 2023, 12:57
To my knowledge all go through cloudflare the difference is the security level and warp is definitely the best security wise
but if you want the lowest latency with the advantage of routing and bypassing the isp throttling HTTPS would be the go
you can check your ping if it is not that high with warp just use it then
KingAzar
Post by KingAzar » 27 May 2023, 19:13
Have been using Wrap+ Unlimited (I'm paying)
However your Game config seems to make the difference from my side, my shots are landing and I don't get those non-sense Ferrari peaks! Or maybe just a placebo?
I have a question, where did you get those extra line commands in the file? The original file doesn't have all of that. Unreal Engine commands?
sherifmagdy32
Post by sherifmagdy32 » 27 May 2023, 20:50
KingAzar wrote: ↑
27 May 2023, 19:13
Have been doing a lot of searching for anything to help with the shit game called fortnite anything to help with the ridiculous fps drops and insane non consistent performance and i put the ones i felt a difference with in the volarant file since they share the same engine and i shared it with my nephew and friends and they noticed a huge difference so decided to share it here to help.
happy to see it is working for you hopefully it does for everyone else.
sherifmagdy32
Post by sherifmagdy32 » 27 May 2023, 20:52
KingAzar wrote: ↑
27 May 2023, 19:13
If you don't mind me asking can you share your specs.
Sebichek45
Post by Sebichek45 » 28 May 2023, 11:06
26 May 2023, 10:47
Sebichek45 wrote: ↑
26 May 2023, 05:00
25 May 2023, 21:44
https://1.1.1.1/
config
virustotal scan
I think it did something. Shots feel more like it hits. However, currently my game is like me feeling more sharp but the enemies also feel more fast and sometimes I die even before I hear the sound of me dying or them swinging.
Maybe its because of my buffers? Currently on 512/256 no rss.
Also is the gameuser config normally empty? Its empty on an account config folder (the jumbled numbers one) but for the pc itself where it inly has gameuserconfig and no riotusersettings it has values in it. Where should I paste it? Should I set it to read-only?
Sebichek45
Post by Sebichek45 » 28 May 2023, 11:07
KingAzar wrote: ↑
27 May 2023, 19:13
How did you set up your network settings? Both for warp and ethernet.
