2023 Esports Optimization Guide
Walkarion
Re: 2023 Esports Optimization Guide
Post by Walkarion » 03 Jun 2023, 15:22
what you do with WUshowhide app? you just hide all updates from microsoft?
MatrixQW
Post by MatrixQW » 03 Jun 2023, 16:13
No!! I just hide drivers.
Walkarion
Post by Walkarion » 03 Jun 2023, 16:36
okey but how you use monitor's audio which have Microsoft driver ,as i see know on my pc its using nvidia driver
MatrixQW
Post by MatrixQW » 03 Jun 2023, 16:50
You need to exclude the HD audio driver from the Nvidia driver installation.
Walkarion
Post by Walkarion » 03 Jun 2023, 17:22
I can exclude HD audio driver when i install driver for nvidia gpu with NVCleanstall? And i understand that you dont update driver for your ethernet thats right?
andreeeeee-
Post by andreeeeee- » 04 Jun 2023, 04:12
MatrixQW wrote:
02 Jun 2023, 21:50
Realtek drivers usually have higher latency for ethernet and audio.
I tested the ethernet Microsoft default Windows driver vs Realtek with Xperf and Microsoft driver has alot less latency.
Hey, I also have a Realtek GBE NIC and I'd like to try this.
Could you tell me the name of the Windows legacy driver that you're using?
There are a lot of options to choose from the device manager list, but I'm not sure which one should I use.
At the moment, with the Realtek driver, my NIC's device service is RTL8167.
InputLagger
Post by InputLagger » 05 Jun 2023, 02:02
andreeeeee- wrote:
04 Jun 2023, 04:12
MatrixQW wrote:
02 Jun 2023, 21:50
Just uninstall the nic device with package removal from device manager and reboot. After, Windows will install correct drivers.
InputLagger
Post by InputLagger » 05 Jun 2023, 02:04
Walkarion wrote:
03 Jun 2023, 16:36
You can uninstall only nvidia audio driver in cpanel
MatrixQW
Post by MatrixQW » 05 Jun 2023, 02:18
andreeeeee- wrote:
04 Jun 2023, 04:12
MatrixQW wrote:
02 Jun 2023, 21:50
I' don't keep old drivers, I use what Windows installs with a clean installation.
I have W10 22H2 and the ethernet driver version is 9.1.410.2015 and the date 10/04/2015.
MatrixQW
Post by MatrixQW » 05 Jun 2023, 02:23
Walkarion wrote:
03 Jun 2023, 17:22
Actually you don't need NVCleanstall, you can just select the graphics driver with Nvidia package and exclude the HD audio and also what InputLagger said but to be fair I never tried Nvidia HD audio driver so it can be fine. If you want to be sure use Xperf from Microsoft and test it.
And yes, ethernet I use Windows default driver.
