Hello,
This is a newly updated list:
List of G-SYNC Monitors
If you see missing monitors, let us know!
Cheers,
*** Official LIST of G-SYNC Monitors ***
- RealNC
Re: *** Official LIST of G-SYNC Monitors ***
Small bug: Sorting by refresh rate doesn't sort correctly. (60Hz messing things up even here
Fixed.RealNC wrote:Small bug: Sorting by refresh rate doesn't sort correctly. (60Hz messing things up even here)
Now Refresh Rate sorts correctly.
StEaK
You forgot the MSI Oculux NXG251R.
- LagBuster
That link (http://www. blurbusters.com/gsync/list) redirects to the FreeSync monitors list, not the G-Sync monitors list.
Good catch, fixed the link.LagBuster wrote: ↑28 Feb 2020, 18:35That link (http://blurbusters.com/gsync/list) redirects to the FreeSync monitors list, not the G-Sync monitors list.
If you remove "www." from blurbusters.com it works correctly. http://blurbusters.com/gsync/list
So we've found a Redirect bug -- fixing that this weekend --
So that both https://www.blurbusters.com and https://blurbusters.com works the same.
- Kaled
Should I be worried that the Asus OLED PG27AQDM isn't on Nvidia's list of G-SYNC Compatible Monitors here? > https://www.nvidia.com/en-us/geforce/pr ... ors/specs/
nSarval
I think the Omen X25f is compatible with G-Sync. I don't use G-Sync but i think it is available.
